7 pro on tmobile
  1. J1537122957753
    Cupcake May 17, 2019
  2. 1plus_batman
    Gingerbread May 17, 2019
    1plus_batman , May 17, 2019 :
    TMO version is locked until you pay it off and updates are slower, also one sim card slot. Buying straight from OnePlus you get faster updates, 2 sim card slots, unlocked phone. Other then that they are the same phone
    Also only the TMO version comes with 256GB thats the only option in size.
    buntycubal likes this.
  3. meatandy
    Oreo May 17, 2019
    meatandy , May 17, 2019 :
    No , one sim from Tmo versus dual SIM from OnePlus and different update path as well.
    Plus what Ryan said above.
  4. stansuys
    stansuys , May 17, 2019 :
    its best to buy on the site of oneplus if you can so you can choose your configuration and you will have 2 sim slots
  5. BigD23
    Froyo May 24, 2019
    BigD23 , May 24, 2019 :
    TMobile version is also missing fnatic mode for some reason. wish I could have purchased unlocked
  6. jayatla
    Eclair May 24, 2019
    Phanitp likes this.
  7. BigD23
    Froyo May 24, 2019
    if I had 700 bucks on hand I would have done the same. OnePlus dropped the ball here, the reason I changed is I was tired of LGs non existent updates. if I'm going to have to go through the same thing here then it's pointless
    dsu2 likes this.
  8. alexoldman
    Eclair May 24, 2019
    alexoldman , May 24, 2019 :
    Also, T-Mobile OnePlus launcher has an option to have 'Google Discover' (feed) on the left pane instead of OnePlus Shelf. The international (unlocked) version does not have this. But it definitely should. :)
    HipsG likes this.
  9. BigD23
    Froyo May 24, 2019
    didn't realize that. mine is default to Google. I am going to return it to TMobile though since it lacks Fnatic mode and will end up with poor update times. I purchased the 12GB version through OnePlus. I don't want to be out of pocket up front but don't want to deal with TMobile nonsense.
    ironass likes this.
  10. Ytkuser
    Gingerbread Jun 6, 2019
    Ytkuser , Jun 6, 2019 :
    always will be a difference in some way or another with a carrier model, the exception is apple products.
  11. PaddiePower
    Froyo Jun 6, 2019
    PaddiePower , Jun 6, 2019 :
    I'm told that if you replace the SIM tray with one from the International version it will function as a dual.
    Whether or not that's true.... I have no idea!
  12. BigD23
    Froyo Jun 6, 2019
    BigD23 , Jun 6, 2019 :
    it is true
  13. cbhl
    Cupcake Jun 7, 2019
    cbhl , Jun 7, 2019 :
    Does the international version of oneplus 7 pro have the same LTE bands as the T-Mobile version?
  14. BigD23
    Froyo Jun 8, 2019
    BigD23 , Jun 8, 2019 :
    Not 100% sure however it works in all of the same places as the Tmobile one did in my area and has just as good if not better reception.
    cbhl likes this.
  15. cbhl
    Cupcake Jun 8, 2019
    cbhl , Jun 8, 2019 :
    Thank you @BigD23
  16. Nyoptical
    Cupcake Jul 7, 2019
    Nyoptical , Jul 7, 2019 :
    I just received mine through T-Mobile I think it's missing the screen protector am I correct?
  17. ffflippp
    Donut Jul 11, 2019
    ffflippp , Jul 11, 2019 :
    no screen protector from TMobile.
  18. Syaoran
    Froyo Jul 11, 2019
    Syaoran , Jul 11, 2019 :
    The T-Mobile firmware version can be flashed to the International/US firmware once you SIM unlock the device. It will then work perfectly fine with a dual-SIM tray. The International/US firmware is limited by the firmware to X16 or CAT 16 where the T-Mobile firmware supports X18 or CAT 18. The updates for the firmware are about 2 weeks behind the International/US firmware but the T-Mobile GM1915 hardware is exactly the same as the 8GB/256GB GM1917. It just comes SIM locked to T-Mobile out of the box and the SIM tray has some extra plastic in it that prevents you from putting in a second SIM. It can easily be removed with a file or sharp razor though, if you don't want to spend the $2 on the replacement.
    Ursocksuntied likes this.
