7 pro
  1. H1520239769271
    Cupcake Dec 5, 2019
    spot01 likes this.
  2. mlulic
    Honeycomb Dec 6, 2019
    mlulic , Dec 6, 2019 :
    What's the error you are getting? Can you even start the application?
  3. H1520239769271
    Cupcake Dec 8, 2019
  4. G_plusone
    Marshmallow Dec 8, 2019
    G_plusone , Dec 8, 2019 :
    Check if Whatsapp Application has Mobile Data Access ?
    Sounds trivial but worth a try
  5. H1520239769271
    Cupcake Dec 8, 2019
  6. G_plusone
    If you give it the permission it will work on Mobile Data
    I hope You're having Mobile Data plans so you won't be charged unnecessarily afterwards
  7. H1520239769271
    Cupcake Dec 8, 2019
    H1520239769271 , Dec 8, 2019 :
    everything is perfect as far as application has to work but even it's not working, I went to store from where I purchased the mobile, they advised me to wait for new software update, I don't know I long I have to wait, it's been 3 month I have this mobile, and this problem also, seems worst mobile I have purchased.
  8. Liehjan
    Lollipop Dec 8, 2019
    Liehjan , Dec 8, 2019 :
    Have you tried to uninstall the app? All your other apps works on mobile data?
  9. H1520239769271
    Cupcake Dec 8, 2019
  10. Liehjan
    You are running what whatsapp version?
  11. H1520239769271
    Cupcake Dec 8, 2019
  12. H1520239769271
    Cupcake Dec 9, 2019
