750mAh for 2h voice call?
  1. mark091991
    Ice Cream Sandwich Mar 19, 2017
  2. darius1988
    KitKat Mar 19, 2017
  3. Akhil_Parujan
    Gingerbread Mar 19, 2017
    Akhil_Parujan , Mar 19, 2017 :
    I don't think it is unacceptable do you?
    I used the same amount of battery for my 2 hour call using OOS 4.1.0.
    I think this is normal unless we could be wrong.
    Can anyone make a 2 hour long phone call using 4.0.3 to see the difference?
    Ferdinandjaeger likes this.
  4. G_Garimella_Sandeep_sfjo
    Froyo Mar 20, 2017
    G_Garimella_Sandeep_sfjo , Mar 20, 2017 :
    I'm on 4.0.3 and facing this voice calls consuming highest battery from long time. For me it's like 650-750 mah for 2 hours voice calls....
  5. G_BPP_PPB_VljA
    Froyo Mar 20, 2017
    G_BPP_PPB_VljA , Mar 20, 2017 :
    is a problem that already has been discussed, it was enough to search in the forum
    - some one say that OP3 consumption is one third
    - and some one else claim that the percentage of statistics on OP3T consumption is wrong
    I try to explain:
    750mAh:120minutes = 6,25mAh/minute
    Total battery 3400mAh:100 = 34mAh each percentage point
    750: 34 = 22%
    Now, it consumed 22 percentage points during the phone calls?
    try to pay attention to it, because also seems to me that the percentage of consumption does not correspond to the mAh consumption declared... so something that does not add up there ;)
  6. Charvel
    Froyo Mar 20, 2017
    Charvel , Mar 20, 2017 :
    Its not related to android 7.x update. I got the same power usage at 3.5.4 - android 6.0.1. One minute call take 6 mAh.
    Since saturday I got 4.1.0 - problem still exist.
