7pro McLaren Overheating
  1. Q1578068293537
    Donut Mar 28, 2020
    Q1578068293537 , Mar 28, 2020 :
    yesterday while using the phone I noticed it was becoming extremely hot so I powered of the phone until it cooled down. I was using the in a area where the sun was shining and trees where prevalent while moving between a shaded area then back to sunlight then back shade and so forth the screen tried to adjust automatically that's when I noticed the phone getting extremely hot had to shut the phone down for a while till it cooled down.
    Side note lately it seems the phone is being bogged down by the memory... Volume doesn't always play you have to physically press the volume button even if phone is already turned up. video don't always play even if loaded sometimes has to load again
    8958385865 likes this.
  2. 8958385865
    Donut Mar 30, 2020
    8958385865 , Mar 30, 2020 :
    i m also facing same problems in my 7tpro McLaren ....heating of phone during charging its temperature reaches to 46degree celsius lag of phone is common
    Q1578068293537 likes this.
  3. ArunKrishnanM
    Donut Mar 30, 2020
    ArunKrishnanM , Mar 30, 2020 :
    Yes. Heating is an issue which i also face with my 7T Pro Mclaren during charging or playing games continuously.
  4. Q1578068293537
    Donut Mar 30, 2020
    Q1578068293537 , Mar 30, 2020 :
    that's unfortunate my issue wasn't with charging though... it was mid use in the wild... I think you guys might want to check out your charger or cable my opinion but I've also seen treads that's say it might be the adaptive feature in system settings
