7T Pro 5G - General Data Signal Bad
  1. B1541111827195
    Cupcake Dec 10, 2019
    B1541111827195 , Dec 10, 2019 :
    Hello, OnePlus Fans!
    I recently upgraded to the 7T Pro 5G, and in the past couple of days I noticed that my signal has absolutely tumbled. Where I would normally have a data connection in my rural area, I now get absolutely nothing. When carpooling to work I would watch a video or something similar and now I have no access to even LTE.
    My APN settings are fine. My SIM is fine. I honestly just wonder if someone has advice, as I'm worried about the investment in this device and wouldn't be able to get my previous phone back as it was a trade-in .
  2. Abhilash_PM
    Froyo Dec 11, 2019
    Abhilash_PM , Dec 11, 2019 :
    Hi. We had seen a similar problem with OP7T. LTE would barely work. Would connect mostly on 3G and very poor data speeds.
    We fixed it by doing the below two things:
    1. Wipe the cache from the bootloader. Here is a tutorial https://support.t-mobile.com/docs/DOC-40182
    2. Then once the phone reboots, go to Settings > WiFi and Internet > SIM & Network > Select the Sim that you are using > Access Point Names > Touch on the 3 dots on top right > Reset to default
    B1541111827195 likes this.
  3. Sir_Pool_de_Float_MD
    Gingerbread Dec 11, 2019
    Sir_Pool_de_Float_MD , Dec 11, 2019 :
    My OP7T Pro 5G was also a bit flaky on first boot up. After the mandatory update, I then factory reset it, and it's been a little better.
    If you still have issues, reach out to T-Mobile support. They also had to made some changes on the backend to re-provision my SIM, and gave me an alternate APN configuration to try.
