T1580732573969 , via OnePlus 7T Pro , Nov 24, 2020 : I have a 7t pro and it does not support wrap charging. It charging normally for the last few days. Can you help me to solve this problem?
Vrushabh_Tawde , via OnePlus 7T Pro , Nov 24, 2020 : How do u know that, it charge normaly and not warp charge? Is ur phone doesn't show warp charging animation.
T1580732573969 , via OnePlus 7T Pro , Nov 24, 2020 : Yeh, my phone doesn't show a wrap charge in the notification before it shows that. It took nearly 3 hrs to full.
chandrahaas02 , via OnePlus 7T Pro , Nov 24, 2020 : Maybe charger with issue try with other one of still persists then I guess you need to visit service centre
the_w1ck3d.One , via OnePlus 7T Pro , Dec 17, 2020 : Are you using the charger and cable that came with your 7t pro or aftermarket?
T1580732573969 , via OnePlus 7T Pro , Dec 17, 2020 : Problem solved. There is dust in the charging socket. I cleaned it with a vacuum cleaner and it starts to work well.
sufi09 , via OnePlus 7T Pro , Dec 22, 2020 : First to check ur charger adapter and charger cable if this not work well u need to get a new charger wrap charge 30. it's available on OFFICIAL ONEPLUS STORE APP.
