7t pro or 7 pro(12+256) via OnePlus 6T
  1. Dr Vipul Dutt
    Froyo Oct 11, 2019
  2. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Oct 11, 2019
    Dr Vipul Dutt likes this.
  3. BobbyV8_
    The Showcase Reviewer Oct 11, 2019
    BobbyV8_ , Oct 11, 2019 :
    Does the bump in 855 to 855+ & warp 30 to Warp30T really matter to you?
    If yes go for 7T Pro if no, go for 7Pro
    Remember that support for both will end at the same time. Also, do you really need 12GB RAM? Invest that excess amount to buy extended warranty or damage protection and have a worry free device experience
    J1508070026278 and Dr Vipul Dutt like this.
  4. Dr Vipul Dutt
    Froyo Oct 11, 2019
  5. camohan
    Marshmallow Moderator Oct 11, 2019
    camohan , Oct 11, 2019 :
    Asumming that you are willing to spend Rs. 54k, I would recommend to go for 7t pro instead of 7 pro, because it has a slightly better processor, 23% faster charging and macro mode (great features for photographer).
    Getting a 7pro with 12 gb does not make sense as there is practically no visible change in performance as 8gb is more than good enough.
    Let's add a twist, if you are not excited for above additional features, why not save Rs. 5k and get 8gb + 256 gb 7 pro.
  6. Radeon962
    KitKat Oct 11, 2019
    Radeon962 , Oct 11, 2019 :
    If they are both approximately the same price for you the 7T will carry a higher resale value as it is perceived as a better phone due to the “T” status. If you keep your phones forever and don’t sell them then get the 7 Pro. Basically the same phone in day-to-day use as you will most likely not notice a difference in your daily interactions with either phone.
  7. atmsriram
    Gingerbread Oct 12, 2019
    atmsriram , via OnePlus 7 Pro , Oct 12, 2019 :
    go for 7 pro 8gb version with ICICI discount u will save 10k , there is nothing new in 7t pro , even charging has been slow down in 7 pro due to 30t charging neednto show fast, check starting of 7 pro 47 % charging would be completed in 20ins and 65 mins for full charge now it's takes 20 mins extra , and macro mode if u really need otherwise it's waste , I am 7 pro. user it's the best
