[Submitted] 7T volume adjustment issue
  1. linameow910910
    Cupcake Apr 7, 2020
    linameow910910 , Apr 7, 2020 :
    Sometimes when I accidentally press power button and volume up at the same time or volume up than volume up + down at the same time, the volume adjustment will go nuts. Basically it goes up to maximum volume itself and won't stop until pressing any of the volume button again.
    Not sure that's exactly how it happened because I'm not really able to re-perform it every time.
    It's quite annoying and it blows my ears when using earphones and creates awkward situation in public (the volume goes up to max and everyone turned to me).
    *I wasn't pressing volume up in the recording. I pressed volume up than volume up + down and it happened. As you can see I tried to drag it down but it goes back up by itself again and again.
    video of proof:
  2. JimBobDuffMan
    Cupcake Jul 10, 2020
    JimBobDuffMan , Jul 10, 2020 :
    I also get this frequently. I can reliably replicate it by pressing the vol up and vol down simultaneously. But it also happens when pressing volume and power as you explained. Very annoying.
