8T TMO fastboot issues
  1. bjoernt78
    Cupcake Jul 31, 2021
    bjoernt78 , Jul 31, 2021 :
    I allowed OEM unlock inside the 8T from T-Mobile but in fastboot mode I get an error:
    Has anyone got the bootloader to unlock ? I tried different Android Bootloader drivers and fastboot versions etc.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 31, 2021
    J4t1np4r3kh and G_plusone like this.
  3. bjoernt78
    Cupcake Aug 1, 2021
    bjoernt78 , Aug 1, 2021 :
    Yes that was what I was originally trying to do but as I can't unlock the boot loader with fastboot I get a "Download is not allowed on locked devices" even if I allow oem unlock from the developer options. Then I tried MSM Tool via EDL mode that gets me into a DDR error so I can't flash it that way either. I seem right now stuck until I find a way to unlock the bootloader via fastboot
  4. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 2, 2021
    Dresa91 , Aug 2, 2021 :
    What about this guide? https://www.thecustomdroid.com/oneplus-8t-bootloader-unlock-lock-guide/
  5. puccellino
    Lollipop Aug 2, 2021
    puccellino , Aug 2, 2021 :
    In the developer options, have you switched on both of the areas shown, or just OEM unlock?
    Might help......but no guarantees. Also I'm presuming you know to allow debugging option.
    Dresa91 likes this.
  6. bjoernt78
    Cupcake Aug 5, 2021
    bjoernt78 , Aug 5, 2021 :
    Correct I have oem unlock enabled but even any command to unlock ends into command failed.
    Followed the latest unlock guide as above and still the same. It feels TMO locked that device down
    and the state is still locked:
  7. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 5, 2021
    Dresa91 , Aug 5, 2021 :
    And you are using the latest Android drivers?
    puccellino likes this.
  8. bjoernt78
    Cupcake Aug 6, 2021
    bjoernt78 , Aug 6, 2021 :
    Supposedly but the drivers I saw still mention a rather old date: DriverVer = 08/28/2014,11.0.0000.00000
    which is odd. It should be version 13 off the android SDK
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 6, 2021
  10. puccellino
    Lollipop Aug 6, 2021
    puccellino , Aug 6, 2021 :
    I think I saw a few articles on the XDA forum.....there are a plethora of drivers. The truth of the matter is, there are not many on this forum who do this any more, and few who can advise well.
    I know someone who might be able to help a bit. @Praty_28, can you help this gentleman?
    Xcommunicad0 and Dresa91 like this.
  11. puccellino
    Xcommunicad0, Dresa91 and Praty_28 like this.
  12. Praty_28
    KitKat Aug 6, 2021
    Praty_28 , Aug 6, 2021 :
    T-Mobile devices have a different method for unlocking the bootloader. You are supposed to get an unlock code right which takes 7 days?
    I'm sure I went through this error while reading through the unbrick tool xda thread and someone had also posted a solution. I'll try to find it for you.
    Xcommunicad0, puccellino and Dresa91 like this.
  13. Praty_28
    KitKat Aug 6, 2021
    Yep, the tag did not work earlier o_O
  14. Praty_28
    KitKat Aug 6, 2021
    https://forum.xda-developers.com/t/...your-device-to-oxygenos.4180837/post-85053037
    https://forum.xda-developers.com/t/...your-device-to-oxygenos.4180837/post-85420063
    I found 2 probable solutions posted by users facing the same ddr error, you can try any of these and check if it works.
    Also, make sure you install this driver and restart your pc, it will help the unbrick tool detect your device. My device wasn't getting detected even tho I tried every single port on my pc. Finally after installing this driver, hitting start on the unbrick tool and using the power plus both volume button combination until black screen, the unbrick process started.
