Network/Connectivity 8T+ with Buds Pro
  1. BorealBlizzard
    Cupcake Dec 1, 2021
    BorealBlizzard , Dec 1, 2021 :
    The Buds pro manual talks about being able to adjust noise suppression and stuff without the need for Hey Melody, however that's not the case for me. Is this just a problem because its a T-mobile exclusive? This is really an issue because Hey Melody keep saying my buds need an update (489) but every time i try it says it succeeds but still prompts for an update.
  2. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Dec 2, 2021
    Best Answer
    Nipu_1998 , via OnePlus 9 Pro , Dec 2, 2021 :
    This seems really wierd.
    Can you try uninstalling all the updates for OnePlus buds app and also clearing the app cache?
  3. BorealBlizzard , via OnePlus 8T T-Mobile , Dec 1, 2021 :
    So after browsing around I guess it's just T-Mobile issues. HEY Melody also decided to stop working, keeps popping up saying it won't work my a OnePlus device. Also went to check if T-Mobile support had anything to say about it and here is what I found.
    What do I do from here because I have no way of changing any of the settings on these anymore.
  4. psygarden
    The Lab Reviewer - OnePlus 9RT 5G Dec 1, 2021
  5. B_Wrath
    Junior Moderator Junior Moderator Dec 1, 2021
  6. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Dec 1, 2021
    Nipu_1998 , via OnePlus 9 Pro , Dec 1, 2021 :
    Have you tried using the Bluetooth menu?
    In the bluetooth devices, select the OnePlus buds pro and you will be taken to a new menu with the earbud controls.
  7. #6
  8. BorealBlizzard , via OnePlus 8T T-Mobile , Dec 1, 2021 :
    Already tried it, when I install the buds app it just doesn't show up in my app menu and when I try and launch it through APK mirrors installer it just doesn't launch.
  9. BorealBlizzard , via OnePlus 8T T-Mobile , Dec 1, 2021 :
    Yes I did. Not getting any of the same options I used to be able to change with Hey Melody.
    opening the menu "headphones" just goes to a blank page
  10. psygarden
    psygarden , via OnePlus 8T Aquamarine Green , Dec 1, 2021 :
    There's not any specific app for the Buds Pro, you'll just find the Settings under Buds Pro in Bluetooth Settings.
  11. BorealBlizzard , via OnePlus 8T T-Mobile , Dec 1, 2021 :
    still nothing however I can't change HD Audio and the about page is new.
  12. BorealBlizzard , via OnePlus 8T T-Mobile , Dec 2, 2021 :
    So removing the buds app got Hey Melody working. Better than nothing I suppose.
    Nipu_1998 likes this.
  13. #13
