2
9 Pro Bluetooth issues
  1. RobMar
    Cupcake Sep 25, 2021
    RobMar , Sep 25, 2021 :
    Oneplus 9 Pro 11.2.8.8
    Ticwatch pro 3 GPS
    Skoda Rapid
    Skoda and 9Pro alone are fine.
    If I wear my smartwatch, Skoda bluetooth won't connect automatically the OP9Pro. I have to manually go in bluetooth setting of 9Pro and connect Skoda.
    Someone has similar issues?
  2. W1632958309997
    Cupcake Sep 30, 2021
    W1632958309997 , Sep 30, 2021 :
    I have issue with the Bluetooth on my OnePlus 8 pro and Soundcore Air Pro earbuds. Everything was perfect for few days and then it started loosing connection when playing music or videos. It is so annoying and it seems like OnePlus has this problem on a lot of its devices. They need to do something to fix this silly issue.
  3. W1632958309997
    Cupcake Oct 2, 2021
    W1632958309997 , Oct 2, 2021 :
    I found the weirdest solution to fix my Bluetooth issues on my OnePlus 8 pro. You won't believe it but the problem with the Bluetooth was caused by the Alibaba app and every time I opened the app the Bluetooth cuts off. Now I have completely removed Alibaba app and no issues with Bluetooth. China is listening and watching you 😉😂😂
  4. ste2709
    Cupcake Oct 11, 2021
    ste2709 , Oct 11, 2021 :
    I have same issue with Kia Sorento 2016 and I noticed dynamic lock on Windows 10 keeps disconnecting. I also cannot use it to activate my Starling app for my kid which requires bluetooth to connect to her oneplus6. On 9Pro 10.2.9.9.LE15DA
    RobMar likes this.
  5. J1548008369100
    Cupcake Oct 25, 2021
  6. I1636097309590
    Cupcake Nov 5, 2021
    I1636097309590 , Nov 5, 2021 :
    OnePlos 9 Pro 11.2.9.9 LE15BA
    Galaxy Watch Active 2
    Skoda Yeti
    i got the same problems as RobMar.
    my car sometimes wont connect to the phone.How can it be that a modern phone has to be connected manualy ???
    With my last phone (Samsung) this has never happend.
    I need this for free speaking because i am a lot on the road.
    !!!URGENT!!!
    Fix this
  7. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Nov 5, 2021
    Liehjan , Nov 5, 2021 :
    Does the Yeti use android auto or normal bluetooth?
  8. C1636228859649
    Cupcake Nov 6, 2021
  9. MkaCologne
    Cupcake Nov 10, 2021
    RobMar and Liehjan like this.
  10. MkaCologne
    Cupcake Nov 11, 2021
    MkaCologne , Nov 11, 2021 :
    ..Nooooo....
    Meantime i have to connect the car ALWAYS manualy again.
    So the Fix above is no solution.
    PLEASE HELP
  11. Jankka72
    Cupcake Nov 25, 2021
    Jankka72 , Nov 25, 2021 :
    No BT connecting to my car either. Car is Volvo XC90 V8 2006. Finds it on search but won't connect. Oneplus 9 Pro. Android11. Works well on other devices. Other phones connects to car but not my OP9pro....help, please!
  12. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 25, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Nov 25, 2021 :
    Can you add the phone from the car side instead?
  13. Jankka72
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 26, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Nov 26, 2021 :
    A long shot but worth a try. There are some Bluetooth related settings in dev options.
    Maybe some makes a difference. My 9 Pro has worked fine with everything Bluetooth related so far.
  15. Jankka72
    Cupcake Nov 26, 2021
    Jankka72 , via OnePlus 9 Pro , Nov 26, 2021 :
    Thanks. Where do I find those? Also found something called Android Auto...don't know yet what that does...
  16. Jankka72
  17. Jankka72
    Now tried all of the above and no change...thank you anyway for trying to help.
  18. Swejuggalo
    You could always report it via the feedback tool in the Community app. Hopefully already solved in the upcomming 12
    #38
    Jankka72 likes this.
  19. MkaCologne
    Cupcake Dec 8, 2021 at 2:57 PM
    MkaCologne , via OnePlus 9 Pro , Dec 8, 2021 at 2:57 PM :
    for now it seems that it has something to do with the mute slider. if it is on normal/ringing BEFORE i start the car, it seems to connect. but not if i slide the button down AFTER the car is running.
    Have to watch this some more.
    #39
