9 Pro difference between CN - Global Versions via OnePlus 7 Pro
  1. B1540972503869
    Cupcake Apr 7, 2021
    B1540972503869 , via OnePlus 7 Pro , Apr 7, 2021 :
    Hey, I live in Australia and the only way I can get a Oneplus phone is from a grey market seller. Most of the Oneplus phones that are available to me are Chinese Versions flashed with Oxygen OS and has Google services installed.
    I was wondering if there was any difference between the Chinese version of the Oneplus 9 Pro compared to the Global version that the rest of the world gets such as different updates, network bands ETC
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 7, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 7, 2021 :
    If converted to Oxygen it gets the same updates. The available bands may be different though.
    So if there is an list of supported bands available for the Chinese version I would crosscheck it with your available carriers. For 5G support there may be additional issues. While you might match a 5G band actually accessing the network may involve additional steps/modifications manually.
    Caoimhín likes this.
