90% battery drain in 7 hours!!
  1. G_Maharshi_Sharma_AJGF
    Cupcake May 21, 2018
    G_Maharshi_Sharma_AJGF , May 21, 2018 :
    I've a One plus 5, purchased it last year. Yesterday night I'd charged my phone close to 95% around 12 am. I never keep it on charging for the whole night. Today morning when I woke up around 7 am and checked my phone, it showed a notification alert of 5% battery remaining! Android system was showing around 60% usage.
    I've tried to remove cache and switched off app backup. But not sure if this would suffice. Seems like something major has gone wrong with the OS, as this is the first time I've faced this issue. Been praising this phone for its battery life, as I easily manage to use it for 2 days with a single charge. Any permanent fixes to this problem would be appreciated.
  2. toastytoast1234
    Marshmallow May 21, 2018
    toastytoast1234 , May 21, 2018 :
    I would suggest :-
    • Fully charge your phone, via a non-dash charger
    • Disable wifi
    • Force close any pirated apps you downloaded from some dodgy repository
    • Orient your phone vertically
    • Sit on it, and swivel.
    I'm pretty sure that this will improve your general experience with your phone, if not the battery life.
  3. I_am_Batman
    KitKat May 21, 2018
    MentalDraco likes this.
  4. Hydra Bob
    Hydra Bob , May 21, 2018 :
    That's called a wakelock right there. Most likely some rogue app is preventing your phone from going to sleep properly. Clear your cache from recovery mode and monitor it for a while to see if it improves. If it doesn't run in safe mode for a while and if that helps start searching for apps to uninstall that might be causing it.
  5. Android450
    Android450 , May 21, 2018 :
    You're back! :eek:
  6. toastytoast1234
    And apparently I'm a giant dick again, I was hoping I'd moved on from that.
    Oh well, it's good to have personal objectives.
  7. Android450
    This place will force it out of you, there's no helping it ;)
    Good to see you after so long
  8. Hydra Bob
    Well don't do it on our regards that's for sure. I for one am finding it rather entertaining thus far.;)
  9. Android450
    Bob! You keep not getting back to me :tearsofjoy: check our group chat
    MentalDraco and Hydra Bob like this.
  10. chirururu
    Donut May 21, 2018
    chirururu , May 21, 2018 :
    What sh*it, he's genuinely asking for [e]1f623[/e] help creep.
    Aman Singh gurjar likes this.
  11. Kirit Abraham
    Kirit Abraham , May 21, 2018 :
    I'm using the One Plus 5 as well and the same thing happened to me yesterday and this was the first time it has happened. Android system usage was 55%. My phone battery last night was around 60% and I woke up today to find my phone dead. A permanent fix for this would actually be appreciated.
  12. Hydra Bob
    A permanent fix would be to use an app to detect the which application was causing the wakelock and uninstall it, but that requires root. Otherwise you're stuck using trial and error to try and track down and remove the app.
  13. G_Maharshi_Sharma_AJGF
    I_am_Batman
    This graph is not giving us much detail. Give us the list of apps usage also.​
    Hi, is this what you are asking for? attached screenshot..
  14. I_am_Batman
    KitKat May 21, 2018
    I_am_Batman , May 21, 2018 :
    I_am_Batman
    Yeah, Seems like Android system's draining the battery. Then follow hydra bob's instructions above
  15. the_o2
    User of the Year 2018 May 21, 2018
    the_o2 , May 21, 2018 :
    I'm sure that this things happening after the latest update, try to clear the cache partition from recovery mode and then check, if not solve then Uninstall the app and re install it one by one and check, If you fell problem in that than factory reset is last option and it's solve your problem completely make sure to backup the data before that..
  16. akshayr723
    Honeycomb May 21, 2018
    akshayr723 , May 21, 2018 :
    That went 0 to real quick
  17. elanglois
    Lollipop May 21, 2018
    elanglois , May 21, 2018 :
    That's OK. I like giant dicks, so it's all good
    Budruel likes this.
  18. elanglois
