90 fps issue via OnePlus 8
  1. N1594547909418
    Froyo Aug 28, 2021
  2. sp5it
    Gingerbread Aug 28, 2021
  3. SIDD7411
    Honeycomb Aug 29, 2021
  4. SarathMx
    Cupcake Sep 2, 2021
  5. Aditya.14_
    Froyo Sep 4, 2021
    Aditya.14_ , via OnePlus 8 , Sep 4, 2021 :
    Bro do you have fps meter in game space?
  6. devmittal29
    Honeycomb Sep 4, 2021
  7. devmittal29
    devmittal29 , via OnePlus 8 Pro , Sep 4, 2021 :
    Enable fps viewer in developers option you'll see it's 60 fps only
  8. pablofg1978
    Head Moderator Head Moderator Sep 6, 2021
    pablofg1978 , Sep 6, 2021 :
    That is totally wrong.
    OnePlus supports 120hz, not fps. It is not the same. 120hz means that the display can refresh the image up to 120 times by second.
    90fps means that the game is generating 90 different images every second.
    So, if the refresh rate is lower or equal to the screen frequency, it is not a problem.
    Some oneplus devices adapt the display frequency to the content that is displayed, lowering or increasing the frequency, to save battery.
  9. Ayanprmnk93
    Froyo Sep 7, 2021
    Ayanprmnk93 , via OnePlus 8 Pro , Sep 7, 2021 :
    the real issue is bgmi developers need to enable the 90 fps output for OnePlus supported devices.. then only once we launch the app, the phone will recognise that it supports higher refresh rate and will keep the refresh rate to 120 or 90 hz(depending on the model). right now we can achieve the 90 fps by enabling force higher refresh rate using adb command.
    The 120/90 hz option in our phone is actually adaptive refresh rate thats y it comes down to 60hz whenever we launch the game. This was not the case with pubg mobile, because in that game the developers had enabled the support... The force higher refresh rate is hidden and can be only accessed using adb command, when once enabled everything will stay at higher refresh rate even though not all apps cam take advantage of this resulting into more power consumption
    OnePlus cannot do anything about it.. only the game developers need to implement this.
    I hope this explanation helps everyone.
    G1594843823245 likes this.
  10. Rajbeermal
    Eclair Sep 18, 2021
    Rajbeermal , via OnePlus 8 , Sep 18, 2021 :
    OnePlus can Fixed this with a update of 90hz support in Battleground mobile india BGMI Has support 90fps in OnePlus 8 so the Game have option to run at 90fps. but the oxygen os software is the issue not the game
    N1594547909418 likes this.
  11. Rajbeermal
    Eclair Sep 18, 2021
    Bro you ever played Pubg mobile on OnePlus 8 series at 90fps it work perfectly at 90fps on my OnePlus 8
    than how i played before pubg mobile at 90fps?
    And Also Check official OnePlus 8 series launch And See What they advertise on pubg mobile Game
    i can tell you what OnePlus advertise is OnePlus 8 series Devices have 90fps support in Pubg Mobile we officially Partner With Pubg to bring 90fps Gaming in OnePlus 8 series
  12. Rajbeermal
    Eclair Sep 18, 2021
  13. Ayanprmnk93
    Froyo Sep 18, 2021
    Ayanprmnk93 , via OnePlus 8 Pro , Sep 18, 2021 :
    nope its not OnePlus issue.. i had raised the support on bgmi helpdesk.. they said they are working on bringing the 90 fps output for more devices.
  14. Rajbeermal
    Eclair Sep 18, 2021
    No bro download the BGMI game and see in graphic settings frame rate goes to 90fps but OnePlus not optimise there software
    And bgmi is saying they will bring this to more devices OnePlus 8 already have this
  15. Rajbeermal
    Eclair Sep 18, 2021
  16. Ayanprmnk93
    Froyo Sep 21, 2021
    Ayanprmnk93 , via OnePlus 8 Pro , Sep 21, 2021 :
    thats just a setting which is enabled.. for providing output as well they have to work with manufacture.. just like in pubg mobile when 90 fps was announced the option was enabled but output wasn't 90 fps.. after a patch was applied we got the output of 90 fps.. so we have to stay patient regarding it..
