4
90 fps not working in bgmi in one plus 7t via OnePlus 7T
  1. S1574828276100
    Cupcake Aug 7, 2021
  2. Leninmadavi125
    Froyo Aug 9, 2021
    Leninmadavi125 , via OnePlus 7T , Aug 9, 2021 :
    Bro give adb command to your oneplus 7t...i had given before few days.....it will help to run bgmi in 90 fps on your device...u can always watch any video on YouTube fir it....check out techibee channel....👍🏻
    Gauraw raj likes this.
  3. ishumittal666 , via OnePlus 7T Pro , Aug 10, 2021 :
    Does this command affect on bgmi id or will there are chances of blocking bgmi id?
  4. Gauraw raj
    Eclair Aug 15, 2021
    Gauraw raj , via OnePlus 7T , Aug 15, 2021 :
    Only issue is that battery will drain very fastly 100% to 15% in just 2h of gaming, otherwise everything will ok.
    ishumittal666 likes this.
  5. Leninmadavi125
    Froyo Aug 20, 2021
    Leninmadavi125 , via OnePlus 7T , Aug 20, 2021 :
    I have faced battery draining issue....😅..... except thiis... everything is just fine....
  6. pa1.
    Ice Cream Sandwich Aug 23, 2021
    pa1. , via OnePlus 7T , Aug 23, 2021 :
    Force 90 Hz using adb or ping bug hunter saying that why they locked the PUBG for 90 Hz and to make developers known about this issue. They have not fixed the issue till now which was present even in Android 10 builds.
    The only conclusion I can come to is either they don't care about 7 series or the developers has started to become incompetent.
    #JustanOpinion
