9pro struck and hang most of the times via OnePlus 9 Pro
  1. Kamalesh1830
    Cupcake Oct 28, 2021
    Kamalesh1830 , via OnePlus 9 Pro , Oct 28, 2021 :
    My oneplus 9pro is less than 3 months old and im facing so many problems like struck some times and hangs most of the times, back navigation doesn't work and it gets hang totally..Anybody who can help me to solve this.Thanks in advance.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 28, 2021
    Caomhin and Tokolozi like this.
  3. Xcommunicad0
    Lollipop Oct 28, 2021
    Xcommunicad0 , Oct 28, 2021 :
    Hi, if you are not on Beta then check if the system storage is not too high. If neither then clear storage of OnePlus launcher, restart and things should hopefully will be better.
    Caomhin likes this.
  4. bhilbern
    Eclair Oct 28, 2021
    bhilbern , Oct 28, 2021 :
    You may have an issue with an app that is running in the background. Try shutting off all background operations and see if that helps. If all else fails; you can try to do a factory reset and start over fresh.
