264
A 10/10 audio experience – Introducing the Bullets Wireless Z
  1. Aditya Pruthi , via OnePlus Community App , May 13, 2020 :
    Can't find apk... Links not working pls can you provide an apk link?
  2. jaimil thakkar
    Gingerbread May 13, 2020
    jaimil thakkar , via OnePlus 7T , May 13, 2020 :
    hey ,i have a question to all whoever is using this earphones
    how it affects the battery life of phone?
    mine is oneplus 7t,as we all know bluetooth always on drains battery, but does this bt wireless will affect so much?
    i am worried bcoz 7t battery life is moderate...so will using this bwz will shorten the btry life of op to a great extent?
  3. Lost_wanderer_07
    Cupcake May 13, 2020
  4. Axy sty , via OnePlus 7 Mirror Gray , May 13, 2020 :
    no that big of an issue if you consider using your earphone for continues 20hr then it will effect around 5%extra battery drain nothing significant in my one plus 7.
    jaimil thakkar likes this.
  5. Axy sty , via OnePlus 7 Mirror Gray , May 13, 2020 :
    it will be delivered soon if you have ordered from OnePlus website bcz they are using DHL/bluedart which is active now.
  6. karthikeyan.m , via OnePlus 7T Pro , May 14, 2020 :
    Axy sty
    it will be delivered soon if you have ordered from OnePlus website bcz they are using DHL/bluedart which is active now.​
    on OnePlus site..
    Ordered On:May 10
    Estimated dispatch:May 19, 2020
    Estimated delivery:May 25, 2020
    Due to the current situation
  7. aashweej
    Cupcake May 14, 2020
  8. jaimil thakkar
    Gingerbread May 14, 2020
    jaimil thakkar , via OnePlus 7T , May 14, 2020 :
    thanks bro
  9. mad_07
  10. SrinivasanSakthivel
  11. _Aditya_Jain_
    Honeycomb May 14, 2020
    _Aditya_Jain_ , via OnePlus 5T , May 14, 2020 :
    Apologies but I can't find anything else related to this feature. Check Play store if there is any app available there.
  12. G_Hemant_Arora_ejux
  13. Axy sty , via OnePlus 7 Mirror Gray , May 14, 2020 :
    it was showing me the same but I received it in in 1 day.
  14. Axy sty likes this.
  15. shadysunn
  16. jaimil thakkar
  17. dharshenk
    dharshenk , May 14, 2020 :
    I bought the bullet z's and recieved them. it was advertised 110ms on fnatic mode but the latency is quite significant on my OnePlus 6t. its really annoying while playing pubg.
    Hariudayan likes this.
  18. jaimil thakkar likes this.
