450
A Peek Inside OxygenOS 11
  1. Ozymandias_Osiris
    Gingerbread Oct 11, 2020
    Ozymandias_Osiris , via OnePlus 8 Pro , Oct 11, 2020 :
    So after installing OOS11 there is no difference for me in using it with one hand ,considering my hand is small its exactly the same for me,only that now the settings menu look like a Samsung UI,pfffff
    LeptitLoS likes this.
  2. shrikstays
    Cupcake Oct 11, 2020
  3. P1547105958923
  4. J1514909363902
    Cupcake Oct 12, 2020
  5. M1570686462126
    Cupcake Oct 13, 2020
  6. Kr_Saksham
    Cupcake Oct 14, 2020
    Kr_Saksham , via OnePlus 8 Pro , Oct 14, 2020 :
    Have you tested the beta version!!? if not then I am suggesting you to upgrade to OOS11. its way cooler than the current OOS10 and WITH THE SAME STOCK ANDROID EXPERIENCE.
  7. Kr_Saksham
  8. Y1594898114276
    S1598629184898 likes this.
  9. HuskyHunter
    HuskyHunter , Oct 14, 2020 :
    So you mean that oos11 is keeping the near stock android experience and not OneUI ?. if that's true I'll happily jump on oos11 when it releases for OP6
    Kr_Saksham likes this.
  10. S1598629184898
    Cupcake Oct 15, 2020
  11. S1598629184898
  12. Maheshsk42
    Donut Oct 15, 2020
    Maheshsk42 , via OnePlus 7 , Oct 15, 2020 :
    Hi OnePlus team, when OnePlus 7 (non pro) will get oxygen OS 11 update?
    It's not outdated device, but still why there is no update or priority?
  13. T1591653406686
    T1591653406686 , via OnePlus 8 , Oct 15, 2020 :
    После обновления на OnePus 8 получил ряд проблем с качеством работы устройства:
    1 Жесты не всегда работают, через раз могу свернуть окно.
    2 Получил сообщение, опустил шторку уведомлений, не могу перейти со шторки уведомлений в месенджер нажав на сообщение.
    3 Приложение "сообщения" не открывается, пришлось скачать "google сообщения".
    Перезагрузка телефона не поправила ситуацию, пробовал многократно)
  14. S1598629184898
    S1598629184898 , via OnePlus 8 , Oct 15, 2020 :
    Found a solution that worked for me, clear chache and data , then open message app, it will work. But do install anothee message app for backing up your old message blbefore clearing message data. Hope it will work for you as well.
    T1591653406686 likes this.
  15. aniketdake
  16. T1591653406686
    Cupcake Oct 17, 2020
    T1591653406686 , via OnePlus 8 , Oct 17, 2020 :
    OnePlus 8
    На приложение "сообщения" появилось обновление спасибо, работает, теперь новая проблема, игры в частности шутеры не скачиваются. Пример у меня была игра call of duty на нее пришло обновление, которое я не смог установить, после многократных попыток исправить ситуацию (очистить кеш Google маркета, перезагрузка устройства), решил удалить приложение и скачать заново, конечно это не помогло. Прошло уже 3 дня борьбы с этим, проблема все ещё присутствует и я подумал установить альтернативу и снова я наткнулся на проблему, я не могу установить PUBG / WarFace / CallofyDuty и на десерт не могу обновить Галерею OnePlus.
    Что делать если с откатом не хочу работать???
  17. Kr_Saksham
