335
A sneak peek into Android 10: Part 2
  1. gizmo91_
    Eclair Aug 30, 2019
    Dgafking0480 likes this.
  2. G_Parthesh_Jadhav_TNSs
    Gingerbread Aug 30, 2019
  3. Kaliqsims
    Eclair Aug 30, 2019
    Kaliqsims , Aug 30, 2019 :
    Definitely will get 10 it's confirmed.
  4. thetaguru
    Froyo Aug 30, 2019
    thetaguru , Aug 30, 2019 :
    So will the 90hz refresh rate be more utilized with this update? Seems like it is wasted on items that do not support it like Google Chrome.
  5. G_Parthesh_Jadhav_TNSs
  6. Kaliqsims
    Eclair Aug 30, 2019
    from what I can see the 90 hrtz refresh rate will be locked for the pixel 4 9n chrome at least but can be forced with adb. games will begin to support 90 in the future also but that is up to them unless you force it.
  7. Kaliqsims
    Eclair Aug 30, 2019
    probably like mid January with how the timeline they have been working on.
  8. SVM911
  9. Swejuggalo
    Lollipop Aug 30, 2019
    Swejuggalo , Aug 30, 2019 :
    I'm not so sure on a stable release right away. My guess would be an open beta first.
  10. ROHAN_DUTTA
    Cupcake Aug 30, 2019
  11. Kishore87544
    Froyo Aug 30, 2019
    Kaliqsims likes this.
  12. Kaliqsims
    Eclair Aug 30, 2019
  13. wanderin.turtl
    Honeycomb Aug 30, 2019
    wanderin.turtl , Aug 30, 2019 :
    for 6 & 6T October 1st week or September last week, and for 7 & 7 Pro by mid Sept
    rickard93 likes this.
  14. wanderin.turtl
    time to sleep, my friend
  15. Kanji Kher
    Donut Aug 30, 2019
  16. Swejuggalo
    Dp4 is not a beta. Developer Preview is a step before the beta stage and is there for developers to prepare apps before official release.
    Closed beta on the other hand is more usable with some bumps along the way like wipes and stuff between some updates. And you are expected to report back to developers in a higher degree. There are also non disclosure agreements.
    Open Beta is even closer to a stable release and there is no real demands to use it.
    The official stable releases could need a extra step. Early adopter opt-in for those that feel quick updates matter the most. That way you could choose if you want to be on the early stage of an rollout (with a chance to get the update before global release) or wait on global release if stability is your major consern.
    P1541520523744 likes this.
  17. C1563633017622
    C1563633017622 , Aug 30, 2019 :
    I have the same problem
  18. Swejuggalo
    If it comes it could come late. Would recommend keeping an eye on Lineage OS. I will support the device with Android 10 based v17 even if it ends up not being released by Oneplus
    ImZlatan likes this.
  19. sheikh shoaib
    Froyo Aug 30, 2019
  20. patrick.barbian
    Donut Aug 30, 2019
    patrick.barbian , Aug 30, 2019 :
    If Android Q for the OnePlus 7 Pro does not appear in the same week as the official Google release, then I go back to Apple. Android sucks.
    fondoo likes this.
