12
A way to have Oxygen rom with Multirom
  1. Jasmohit
    Jelly Bean Apr 4, 2015
    Jasmohit , Apr 4, 2015 :
    If you wanna test the ROM but you are experiencing bootloop while doing so.I can help you .Just follow these instructions
    First flash cm12 nightlies or any other lollipop rom bcoz its not working with cm11s.You can try that on your own risk.
    Then flash this zip http://forum.xda-developers.com/one...ltirom-v26-t2835738/post59907538#post5990753
    It won't work now
    Afterwords install multirom app from Google play and it will install what is required
    Then you can flash your oxygen ROM and voila you are done.
    It is done and now you can switch ROMs.Plz hit the like button and hope I helped
    A.S, rick97, naveen70707 and 9 others like this.
  2. Jasmohit
  3. Jasmohit
  4. Jasmohit
  5. HTK
    Honeycomb Apr 4, 2015
    Jasmohit likes this.
  6. Jasmohit
    okay thats duplicate.Well i thought I could help someone
  7. 0xTJ
    Gingerbread Apr 4, 2015
    0xTJ , Apr 4, 2015 :
    This might be interreasting as I do not want to switch, waiting for 12S, but it might be interesting to try.
  8. Wieczor
  9. HTK
    HTK , Apr 4, 2015 :
    Maybe is not. Maybe it is maybe maybe.
  10. ianseer
    ianseer , Apr 4, 2015 :
    i like it.. even i dont want to try it for now.. but maybe someday this could be useful.. nice share mate !
  11. Jasmohit
    Yes i didn't wanted to switch too.So i just did multirom with that rom bcoz i have 10 gb of games only
  12. Wieczor
    Wieczor , Apr 4, 2015 :
    what if I already installed it on multirom booter (didnt work) rebooted and can I do what you wrote ?
  13. Jasmohit
    Oh thanks plz be sure to give it a like.
  14. Jasmohit
    you mean to say if you had made it a primary rom.Yes if you had backup or other rom you can do it for sure
  15. Jasmohit
    So don't say that atleast
  16. Wieczor
  17. Jasmohit
    it will boot up then for sure
  18. Wieczor
    Yep I can confirm.
    This is easiest way to Multirom Oxygen OS
    Great Job
  19. Jasmohit
    Guess i did a gr8 job.Should i say mods to stick it so that people can have multiple testings?
  20. HTK
    HTK , Apr 4, 2015 :
    Mybe i read it incorrectly. My badddd
