About charger
  1. F1528046765764 Cupcake Jun 20, 2019
  2. SeeBeeEss Ice Cream Sandwich Jun 20, 2019
    SeeBeeEss, Jun 20, 2019 :
    You can use the new warp charger. It will charge your OnePlus 6 at dash/rapid speed. I believe that the dash/rapid charger is being discontinued in favour of the warp charger.
    Kytharsis and Matt 80 like this.
  3. F1528046765764 Cupcake Jun 20, 2019
    F1528046765764, Jun 20, 2019 :
    oneplus customer care representative said it is not usable for OnePlus 6 what shoud i do .
    if its not working
  4. SeeBeeEss Ice Cream Sandwich Jun 20, 2019
    JP Llaga, Kytharsis and Matt 80 like this.
  5. Matt 80 Lollipop Jun 20, 2019
    Matt 80, Jun 20, 2019 :
    The representative who told you that doesn't know what they're talking about.
    It will work perfectly fine.
  6. Roger.T Jelly Bean Jun 20, 2019
    Roger.T, Jun 20, 2019 :
    Why do you ask something like that?
    Each OnePlus 6 comes with a Dash Charger.
    And if you mean Warp Charge, then you're out of luck because The OP6 / T did not integrate this technique...
    Kytharsis likes this.
  7. RyanMixed Froyo Jun 21, 2019
    RyanMixed, Jun 21, 2019 :
    he's dash charge might be broken or destroyed now.
  8. F1528046765764 Cupcake Jul 14, 2019
  9. JP Llaga Eclair Jul 14, 2019
    JP Llaga, Jul 14, 2019 :
    Any OnePlus red cable that 6T have is compatible with the 6, Just buy a new power brick like the Warp Charge or 6T's Rapid Charger... ok?
