About OnePlus 9 pro bug issue via OnePlus 9 Pro co-developed with Hasselblad
  1. #1
  2. TibiTibi
    Photography Expert Community Expert Nov 27, 2021
    TibiTibi , Nov 27, 2021 :
    Do you use back cover?
    Do you feel strange behaviour when you are changing the modes with a slider?
    Do you have mechanical issues with the slider?
  3. Aaron2017
    General Support Expert Award 2021 Nov 28, 2021
    Aaron2017 , Nov 28, 2021 :
    If you press the power and volume up button at the same time does that put the phone to vibrate mode? You will only see a very brief toast message at the bottom of the screen saying that the phone is set to vibrate, and it'll say that below the clock in the notification panel too if you swipe that down, it will not show the vibrate icon in the status bar. I ask because maybe you trigger that by accident without knowing, this has happened to me plenty of times before when i accidentally and without knowing pressed the power and volume up buttons when i picked up my phone.
  4. TibiTibi
    Photography Expert Community Expert Nov 28, 2021
    TibiTibi , Nov 28, 2021 :
    Is this a 9pro feature? I cannot reproduce that on 8T.
  5. the_o2
    OnePlus 9 Series Expert Community Expert Nov 28, 2021
    the_o2 , Nov 28, 2021 :
    It happens on few devices, mine just off the screen when I press volume up and power button together :sweatsmile:
  6. Aaron2017
    Apparently it only happens on certain devices, it's not even region specific as i know others with the same phone and EU ROM who can't reproduce it either. But i have it on all 3 OP devices.🤷
  7. Helder_DAlmeida
    Marshmallow Nov 28, 2021
    Helder_DAlmeida , via OnePlus 9 Pro , Nov 28, 2021 :
    Can't reproduce it on my 9 Pro
    Caomhin, the_o2 and Aaron2017 like this.
  8. TibiTibi
    Side note:
    Sometimes when i put my phone on desk or into pocket the phone turns on the torch.
    It could have the similar base.
    Helder_DAlmeida, the_o2 and Aaron2017 like this.
  9. Aaron2017
    Yup, weird why some can and some can't.🤷
    That's possible yeah. At least there's an option in beta 2 of Oxygen OS12 to turn the power and volume key shortcut off so that's one annoyance less in my case
    Caomhin, Helder_DAlmeida and TibiTibi like this.
  10. Rebel Rouser
    Froyo Nov 28, 2021
    Rebel Rouser , Nov 28, 2021 :
    Had that same problem using a wallet type case with magnetic type closing straps. Every time I closed or opened it the switch changed to a different setting.
    TibiTibi likes this.
