Hello,I am here to give a detailed review on OnePlus Bullets Wireless 2.
Buckle up, Let's go for a ride[e]1f680[/e]
I have spent a lot of quality time with Bullets Wireless 2 and I am going to speak about:-
A) Design and Fit
B) Technology
C) Connectivity
D)
Sound and Call Quality
E) Controls
D) Charging and Battery
DESIGN
Bullets Wireless 2 design is neat, clean and minimalistic. The sea-Shell design stands unique from others. They are combinedly made of Aluminium and Plastic. The aluminium part is slippery that it may slip out of the hands when holding the earpiece alone. The aluminium part gives a richer look to the earphones,the plastic part sits inside the ears so they don't damage the looks of earphones. The rubber band is soft and sits comfortably over the neck. The strings are made of good quality rubber, however a bit extreme use may break them. A red plastic outer lining gives a visual appeal. Bullets wireless 2 are not IP certified
FIT
Bullets Wireless 2 fits really good into ears. Their extended tips allows them to sit inside ears without causing any pain to internal or external ears. Silicon rubber tips make them more comfortable to fit in years at the same time providing passive noise cancellation. The passive noise cancellation is so good that, sometimes I use them just as earplugs while sleeping, they cancel around 60% of the ambient sound. The earbuds are totally weightless that I don't feel them sometimes. The neck band is soo soft and doesn't harm the neck at any instance. But the neck band tends to fallout rarely while sleeping(might not happen to all) but are good for jogging. They are not IP certified so they are not suitable for workouts and sweaty works. They don't have rubber fins like the original version but I don't feel its need.
RATING: 8.5/10
Inclusion of silicon ear tips might be good.
IPX 4 certification would be good.
TECHNOLOGY
Bullets Wireless 2 is a hybrid earphone. They pack 3 drivers on each earbud, One dynamic 10mm driver and two balanced armature drivers. The two Knowles armature drivers are present to increase the clarity of sound to greater extent. It comes out with Qualcomm's AptX HD which improves the quality of the sound. There is a notable difference when the AptX HD is on and off, they are a good addition. To increase call quality Qualcomm's CVC technology is present which records a decent audio in noisy environment. It comes with Bluetooth 5.0 which provides good connectivity. Qualcomm's CVC technology for calls is present but I feel like it does nothing.
RATING: 7/10
12mm dynamic drivers instead of 10mm could be better for that price range.
Environmental Noise Cancellation can be included with 1 or 2 extra microphones on each earbud instead of Qualcomm's CVC.
CONNECTIVITY
I have tested connection possibilities with 3 devices.
OnePlus 6: OnePlus fast pair is seamless, it connects in an instant. I have never faced any connectivity issue yet with Bullet Wireless 2 on Oneplus devices. They connect to the device even before I fit them into my ears, Sometimes I check my status bar whether they are connected are not because I am late for the connected sound and every time they did. The Quick Switch also feels instant, they take a maximum of 2 seconds to switch. I never faced a connection loss issue on oneplus 6. They have a decent range of 7-8m (but claimed as 10m)
Redmi Note 8 Pro: I need to connect them every time from the bluetooth settings which is little irritating, but they connect instantly after the tap. Quick switch works instantly with the device.
Asus TUF Laptop: With the recent introduction of Quick connect in Windows, the connectivity experience is good but they don't connect both voice and music at the first try, i need to disconnect and connect several time which is a bit frustrating. I faced a lot of connection issues in the recent week but after a factory reset everything worked fine. The Quick switch works instantly like the other 2 devices.
RATING: 8/10
The connectivity possibilities with laptops must be explored.
SOUND
TESTING ENVIRONMENTS:
Zero ambient sound
Loud sound under a sound bar
Travelling
Under zero ambient sound everything was crisp and clear. The armature drivers has payed a lot with very good high frequencies, the vocals are very clear and the unheard background music from a song can be heard for the first time. The highs and upper mid frequencies are really good. AptX HD brings a very notable difference, while they are on the sound is boosted without any distortion. The only place where I was not satisfied was the low frequencies, the bass was not very good compared to the compeitetors, The bass could have been boosted a little more. Some consumers enjoy low frequency song more than anything else. Other than the lower frequency, it is an immersive experience which most of them will enjoy. I enjoy melody songs the most on Bullets wireless 2.
Under a sound bar the passive noise cancellation was put to a test and i was pretty impressed. I still was able to hear better vocals, this where they surprised me. But with a larger driver it would have been a more better experience under a noisy environment. The sound quality was good but it has the potential to be more good with better dynamic drivers.
I had the best travelling experience ever accompanied with Bullets Wireless 2. I generally spend huge amount of time watching movies while travelling and I never felt disturbed. The quality of the sound was nearly same as the zero noise environment. Bullets Wireless 2 are my best buddies while travelling.
GAMING
I have spent countless hours of gaming with Bullets wireless 2. I have very mixed feeling in gaming. Because of armature drivers the clarity is so clear I can detect enemy approach easily with a clear audio while activating grenade and throwables. The audio is really good and clear i all the games I ever played. The real problem is with latency, I notice audio latency while playing multi-player games. There is a notable lag in PUBG and other battle royale games. Bullets wireless 2 is not really meant for hardcore gamers.
RATING:
AUDIO: 8/10
GAMING: 6/10
Better Dynamic drivers could have given a more beautiful overall experience
CALL QUALITY
TESTING ENVIRONMENT
Zero Ambient Sound
Home conditions with electricals running
Noisy Bus Station
The audio was pretty clear but there is disturbance even in quite environment. The quality could have been more better. My friends on call heard a little amount of noise in quite environment. The call quality could have been a little better at least in zero noise environment. I am attaching a audio file recorded with bullets wireless 2 under no noise environment.
https://drive.google.com/file/d/15EJg7h28dr8K1W6YULLGHMI4NjPMoZLV/view?usp=drivesdk
Under a little noisy environment the audio is little distorted. I was not at all happy with the call quality because my friends weren't able to hear me clearly, there was continuous disturbance. The background noise was heavier than my audio, so the call quality should improve a lot. I am attaching a audio file recorded with bullets wireless 2 in home conditions with electricals running .
https://drive.google.com/file/d/15Cgdj6sGXySQvlYd-ecOWdvdTciz5twA/view?usp=drivesdk
Everyone can clearly expect what the result could be, the audio was not at all clear, there was a whole lot of noise. Not even all the noise canceling earphones cancelling earphones can do good in this environment. I didn't expect a lot in this segment. Call quality should be improved a lot.
RATING: 5/10
This the big con in BULLETS WIRELESS 2. Number of microphones could have been increased which could have acted as a noise cancelling microphones to some extent.
Qualcomm's CVC isn't that good
CONTROLS
One of the best addition from the original version is the magnetic controls. Connecting them together pauses the music and separating them plays the music. I love the magnets soo much that I play with them when i'm bored. Then there is a classic 3 button in-line remote, a volume increase button, a volume decrease button and another central button which skips to next track on double click, plays previous track on triple click , single click to pause/play music. However I was not impressed by the remote because of the noticeable lag. Switching between two connected device has never been easier before Bullets Wireless 2. As stated before the quick switch is instantaneous.
FYI, The audio cutoff is made by the right earpiece
RATING: 8.5/10
The remote could have better.
CHARGING
OnePlus has excelled in charging department from a long time, they've done it again. Charge for 10 minutes listen for 10 hours. I never regretted that I didn't charge my buds earlier. The warp charge is excellent. For full charge it must take 150 minutes as stated but It gets charged under 45 minutes. Oneplus introduced a new warp charge technique with BW2, we don't need a fast charge brick to warp charge. It charges at a high speeds with any charger and even with laptops which is amazing.
BATTERY
Bullets wireless 2 has one of the best battery technology. 10 hours music on 10 minutes charge is no small thing. They are said to serve for 14 hours on full charge but in my conditions it serves a little bit more longer than that. I usually use them around 7-8 hours a day. So I charge them twice a day. I have been using them for nearly a year and the battery life is not compromised yet.
RATING: 9.5/10
FINAL VERDICT
OnePlus Bullets Wireless 2 is a great improvement over the original one. The audio quality has increased a lot but it is not satisfying in every frequencies. The call quality must be improved which is important. They are not match for gamers and fitness freaks.
Overall Rating: 7/10
