Accubattery & battery health
  1. Spigkos
    Gingerbread Jan 6, 2018
    Spigkos , Jan 6, 2018 :
    Just out of curiosity , is anyone using this app to monitor what using the most out of its battery?
    Was wondering what is your battery health and estimated capacity.
    Mine shows 90% and 3000mah. Can it be correct? it is not even a month that i purchased it.
    Strikeblaze likes this.
  2. Onji
  3. Jesusmanuel22
    Jesusmanuel22 , Jan 6, 2018 :
    That's not accurate or correct. Don't worry about that, just keep in mind how much it lasts now so in a future you notice if the battery is draining significantly faster because of an update or faulty battery
    Spigkos likes this.
  4. stark2991_PL
    KitKat Jan 7, 2018
    stark2991_PL , Jan 7, 2018 :
    AccuBattery shows 98% health on my 3-year-old HTC One M8. Let it be the best answer how accurate this app is
    Spigkos likes this.
  5. MentalDraco
    Marshmallow Jan 7, 2018
    MentalDraco , Jan 7, 2018 :
    I drained the phone fromm 100 % to 1 and then added up the mAh from battery stats, it equaled about 3000 mAh, so depending on how accurate the system battery info is then accubattery is very accurate
    Spigkos likes this.
  6. Spigkos
    Gingerbread Jan 7, 2018
  7. MentalDraco
    That is the question. Well for starters a part of the battery is probably not accessible, to keep the battery from fully draining, then the question is how accurate the information from the battery info is, dose it log all the drain? I am trying a few apps that log apps and drain to see what adding up the mAh from those says.
    Spigkos likes this.
  8. Anand_Nair
    Anand_Nair , Jan 7, 2018 :
    man.. Never believe much on those apps!
    every battery has got some charging cycle life and it will reduce by a fraction with every time u fills and uses the juice.
    just use it the way u want n keep in mind that it will be good for at least 2 years
  9. Strikeblaze
    Eclair Jan 7, 2018
    Strikeblaze , Jan 7, 2018 :
    I am using accu battery.It does not give exact reading of how much your actual battery. I like how it gives detailed status about sot for which I use it.
    Spigkos likes this.
  10. Adrianohio
    Cupcake Feb 5, 2018
    Adrianohio , Feb 5, 2018 :
    I've had the OnePlus 5t for 2 months and my battery health shows only 2,999 mAh
    stefano.zampieri.hm likes this.
  11. MarcioReis87
    Ice Cream Sandwich Feb 5, 2018
  12. guardianzpride
    Gingerbread Mar 21, 2018
    guardianzpride , Mar 21, 2018 :
    Hi guys..today I discharged battery to 1% and charge it to 100% and left it another 30 mins more. This is what I got with USB meter...
    I have phone since July 2017 as 2nd device with very light use.
    How is possible battery got so much degrade??
  13. stark2991_PL
    KitKat Mar 21, 2018
    stark2991_PL , Mar 21, 2018 :
    You don't know if it's degraded because you don't know what are the results on the new phone
    Besides, do you FEEL it's degraded? Do you have low SoT?
  14. guardianzpride
    I dont have low sot m8. My sot is very good with latest stable rom.
  15. stark2991_PL
    KitKat Mar 21, 2018
    So stop looking for a problems :)
