Adapter and chord got soaked with perfume!(HELP!)
  1. ruel61
    Cupcake May 30, 2018
  2. ruel61
  3. youbi
    Head Moderator Head Moderator May 30, 2018
    youbi , May 30, 2018 :
    I would make sure that its really dry and that it didn't damaged something on it.
    How did that happen? :eek:
  4. ruel61
    ruel61 , May 30, 2018 :
    How to dry it up?just leave it for one day?i dont know,when i opened my bag,the perfume bottle was loose already and empty.
  5. youbi
    Really bad luck. :(
    Before trying to connect it and dry you could maybe try to clean it a bit with a slightly humid cloth just to remove the perfume from it. Not sure if the perfume can do some damages in the long run to it.
    And then let it dry and then test it carefully, first just the charger and without connecting anything to it and then cable, and if nothing weird happens try the phone, but I would keep an eye for something strange. Because you can't be sure how much perfume may have got in and what damage it may have caused. :(
  6. iNtEnSePL
    KitKat May 30, 2018
    pkcable likes this.
  7. kumaryashwin
    Jelly Bean May 30, 2018
    kumaryashwin , May 30, 2018 :
    Perfume already has alcohol content. Just let it dry. And uses it then as well get the scent of charging for coming months.... [e]1f602[/e]
  8. iNtEnSePL
    KitKat May 30, 2018
    iNtEnSePL , May 30, 2018 :
    I know, but also has lots of oils, which don't help
  9. Majed.HQ
    Gingerbread May 30, 2018
  10. kumaryashwin
    Not much oil which may harm circuitry, but for safety it will be fine to use it after one day.
    I guess.
  11. pkcable
    pkcable , May 30, 2018 :
    I would clean it with as pure alcohol as you can find (denatured, cleaning alcohol), then let it dry for a day or two. Using a desiccant (that the right word?) such as uncooked rice, or better silica packs, to draw out any remaining moisture.
    meatandy likes this.
  12. meatandy
    Oreo May 30, 2018
    meatandy , May 30, 2018 :
    Twirl it around like a jump rope and a force will pull most of the moisture water off , then wipe off any residual or the paper towel.
    xnutzii and Budruel like this.
  13. G_Sunny_Shaw_caum
