Adaptive brightness does not work
  1. devb23
    Eclair Oct 22, 2020
    devb23 , Oct 22, 2020 :
    Since last update my adaptive brightness feature is broken ...from quick toggle area I can enable and disable adaptive brightness and the bar slides too but it does not change the brightness...It simply means it is broken for manual use as well.. please fix it
  2. Rajendra.Bhat
    Jelly Bean Oct 22, 2020
    Rajendra.Bhat , Oct 22, 2020 :
    Hard reset will fix it
  3. devb23
    Eclair Oct 22, 2020
    Hard resetting does not seem to be a fix for me
  4. Artemus.
    Nougat Oct 22, 2020
    Artemus. , Oct 22, 2020 :
    It's not gonna make a huge difference considering it's based on the amount of available light in the immediate area, not to mention it's AI-powered so it has to learn your habits as you go.
  5. devb23
    Eclair Oct 22, 2020
    I understand how adaptive brightness works..but my concern is that it's not working fine even if I switch it on and off manually...it will stay on high brightness even when it's dark
  6. Artemus.
    Nougat Oct 22, 2020
    Again, "it's AI-powered so it has to learn your habits". Meaning you have to manually adjust the brightness whenever you need it changed and it'll learn from that. People wanted AI, now they have it and have to teach it.
