Adaptive Display Issue
  1. MOHAMMAD_AMEEN
    Eclair Jul 27, 2019
    MOHAMMAD_AMEEN , Jul 27, 2019 :
    Since the new update, I am facing issue in my display sensor.
    Sometimes in low light it turn the brightness to the maximum and if I am under the sun it keep the brightness to the least which makes the screen totally black.
    While watching videos, even if I am on my seat without any movement, the brightness keep fluctuating.
  2. the_o2
    Marshmallow Jul 27, 2019
    the_o2 , Jul 27, 2019 :
    Adaptive brightness takes few days to learn your usage pattern, after that it will settle down.
    But it still behaving like that better to
    report this here
    https://forums.oneplus.com/feedback
  3. MarkoBatrac
    Honeycomb Jul 27, 2019
  4. Filepp
    Gingerbread Jul 27, 2019
    Filepp , Jul 27, 2019 :
    Light sensor have some problems in op7 pro, often it increase or decrease light random
  5. toothy360
    Donut Sep 12, 2019 at 8:01 PM
    toothy360 , Sep 12, 2019 at 8:01 PM :
    the best way to fix the issue with adaptive display is to be able to put a minimum to where the lowest screen brightness can go but sometimes it just gets too dark
