ADB driver not working on Win10?
  1. jordym
    Honeycomb Aug 15, 2015
    jordym , Aug 15, 2015 :
    I was rooting my device with CM12.1 nightly but in the moment to push superSU 2.46 on my device, it told me that the device was not detected although debugging is checked and The driver seems to be working proprely even after uninstall/reinstall any ideas?
  2. yahiroz
    Jelly Bean Aug 15, 2015
    yahiroz , Aug 15, 2015 :
    As far as I know there are no properly working ADB drivers for Windows 10. You will need to wait for someone to update their ADB package to be compatible. I usually use the universal ADB drivers from koush but that's not compatible either. People has posted on XDA reporting the same issue as well.
  3. chirantanad
  4. Aztriltus
    Cupcake Aug 16, 2015
    Aztriltus , Aug 16, 2015 :
    Fastboot, adb all working with Windows 10. Flashed twrp on my OP2 just fine using the toolkit
  5. waicool20
    Gingerbread Aug 16, 2015
  6. chirantanad
    Honeycomb Aug 16, 2015
    chirantanad , Aug 16, 2015 :
    INCORRECT..I'm still using ADB Commands to flash cyanogen rom on WINDOWS 10
  7. yahiroz
    Jelly Bean Aug 16, 2015
  8. jordym
    Honeycomb Aug 17, 2015
    jordym , Aug 17, 2015 :
    I have exactly the opposite, Fastboot is working proprely but pushing with ADB is not :/ i had to finish my root by drag and drop
  9. drai2
    Donut Aug 18, 2015
    drai2 , Aug 18, 2015 :
    Hi guy,
    can you make me understand what you have now?
    OP2 with CM12.1 nightly? I'm new in rooting
    Is your mobile system completely different from the one that I received?
  10. yahiroz
    Jelly Bean Aug 18, 2015
    yahiroz , Aug 18, 2015 :
    I don't have the OP2 but my HTC One M7 and Nexus 10 are both unlocked and rooted, so I usually fiddle with ADB/fastboot on both devices. I use the universal ADB/fastboot driver from koush so it saves me the hassle of installing drivers for different devices.
    Also, OP2 comes with Oxygen or Hydrogen OS, depending on where you bought it. There is no official Cyanogen OS for the phone.
