adb sideload cannot read .....
  1. ghostofcain
    Marshmallow Mar 15, 2018
    #41
  2. F_Akhil_rlCY
    Froyo Mar 15, 2018
    #42
  3. ghostofcain
    #43
  4. F_Akhil_rlCY
    Froyo Mar 15, 2018
  5. ghostofcain
    ghostofcain , Mar 15, 2018 :
    Try copying and pasting it into a browser works fine for me.
    Failing that try googling "how to install adb drivers on windows 10" if you can't figure it out from there I'd stay away from fastboot if I was you
    #45
  6. F_Akhil_rlCY
    Froyo Mar 15, 2018
    F_Akhil_rlCY , Mar 15, 2018 :
    i am not doing this for first time.this is my new laptop.and i want to root it again
    #46
  7. mhak0v3y
    Donut Mar 28, 2018
    mhak0v3y , Mar 28, 2018 :
    the problem is that u have to write THE ADRESS OF THE ZIP
    adb sideload OnePlus5Oxygen.zip = WRONG
    adb sideload C:\users\Desktop\OnePlus5Oxygen.zip = RIGHT WAY to do it
    i had the same problem until i understood it...
    #47
  8. idkwhoiam322
    Nougat Mar 28, 2018
    idkwhoiam322 , Mar 28, 2018 :
    Depends on where you open cmd(or powershell). If it's opened from the directory itself, the first command will work just fine.
    #48
    Hydra Bob likes this.
  9. Mrokus
    Cupcake Mar 22, 2019
    Mrokus , Mar 22, 2019 :
    I used TWRP 3.2.1 bluspark and install Oreo build first without issues. I did not use ADB sideload becouse of "cannot read".
    I don`t know where here can find old versions, used russian forum:
    Stable: https://4pda.ru/forum/index.php?showtopic=832047&view=findpost&p=78867642
    Beta: https://4pda.ru/forum/index.php?showtopic=832047&view=findpost&p=78456834
    After install stock recovery and get OTA updates to get latest Android 9. Also I lock fastboot, it was my main porpose.
    #49
