13
AdBlocker Quick Settings Tile [AppFactory apk and Tasker XML]
  1. Dr. Indest
    Lollipop Feb 13, 2018
    Dr. Indest , Feb 13, 2018 :
    Often times, I see myself having to disable AdAway to use a Google Shopping or a Slickdeals link. This involved a process of exiting my browser, launching AdAway, disabling AdAway, going back to the browser, opening the desired link and then re-enable AdAway through the same process of exiting the browser to open AdAway again. Surely there was a simpler method! Attached below, I have posted a Tasker xml file that adds a Quick Setting tile to your system and allows users to enable/disable their AdBlocker. This uses the same sources as AdAway, but works independent of the app. Therefore, you don't need AdAway for this to work.
    I have also included a compiled APK, using Tasker's AppFactory, for you fiscal conservatives who don't want to buy Tasker.
    Coming soon: A unique icon....
    To note, if you are using systemless root, like MagiskSU, you must enable systemless hosts in the settings of MagiskSU/root client.
    Special thanks to my telegram pals Armando and Esperanza, for their help in testing the task.
    For those afraid of the download button, a copy of the xml file can be found below:
    Code:
    <TaskerData sr="" dvi="1" tv="5.1m">
        <Task sr="task2">
            <cdate>1496603118566</cdate>
            <edate>1518553585876</edate>
            <id>2</id>
            <nme>AdBlocker</nme>
            <pri>100</pri>
            <Kid sr="Kid">
                <launchID>2</launchID>
                <pkg>rxb.srv.ila</pkg>
                <vnme>v5</vnme>
                <vnum>5</vnum>
            </Kid>
            <Action sr="act0" ve="7">
                <code>342</code>
                <Int sr="arg0" val="5"/>
                <Str sr="arg1" ve="3">/sdcard/AdBlocker/status/status.txt</Str>
                <Str sr="arg2" ve="3">%old_status</Str>
                <Int sr="arg3" val="0"/>
            </Action>
            <Action sr="act1" ve="7">
                <code>37</code>
                <ConditionList sr="if">
                    <Condition sr="c0" ve="3">
                        <lhs>%old_status</lhs>
                        <op>2</op>
                        <rhs>false</rhs>
                    </Condition>
                </ConditionList>
            </Action>
            <Action sr="act10" ve="7">
                <code>512</code>
                <Int sr="arg0" val="1"/>
            </Action>
            <Action sr="act11" ve="7">
                <code>548</code>
                <Str sr="arg0" ve="3">Enabling AdBlocker</Str>
                <Int sr="arg1" val="0"/>
            </Action>
            <Action sr="act12" ve="7">
                <code>162</code>
                <Str sr="arg1" ve="3">AdBlocker</Str>
                <Int sr="arg2" val="0"/>
            </Action>
            <Action sr="act13" ve="7">
                <code>118</code>
                <Str sr="arg0" ve="3">https://adaway.org/hosts.txt</Str>
                <Str sr="arg1" ve="3"/>
                <Str sr="arg2" ve="3"/>
                <Str sr="arg3" ve="3"/>
                <Str sr="arg4" ve="3"/>
                <Int sr="arg5" val="10"/>
                <Str sr="arg6" ve="3"/>
                <Str sr="arg7" ve="3">/sdcard/AdBlocker/adaway.txt</Str>
                <Int sr="arg8" val="0"/>
            </Action>
            <Action sr="act14" ve="7">
                <code>118</code>
                <Str sr="arg0" ve="3">http://winhelp2002.mvps.org/hosts.txt</Str>
                <Str sr="arg7" ve="3">/sdcard/AdBlocker/mvps.txt</Str>
            </Action>
            <Action sr="act15" ve="7">
                <code>118</code>
                <Str sr="arg0" ve="3">http://hosts-file.net/.%5Cad_servers.txt</Str>
                <Str sr="arg7" ve="3">/sdcard/AdBlocker/hphosts.txt</Str>
            </Action>
            <Action sr="act16" ve="7">
                <code>118</code>
                <Str sr="arg0" ve="3">http://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&amp;showintro=0&amp;mimetype=plaintext</Str>
                <Str sr="arg7" ve="3">/sdcard/AdBlocker/yoyos.txt</Str>
            </Action>
            <Action sr="act17" ve="7">
                <code>123</code>
                <Str sr="arg0" ve="3">sort -u /sdcard/AdBlocker/*.txt &gt; /etc/hosts</Str>
                <Int sr="arg2" val="1"/>
                <Str sr="arg5" ve="3"/>
            </Action>
            <Action sr="act18" ve="7">
                <code>410</code>
                <Str sr="arg0" ve="3">/sdcard/AdBlocker/status/status.txt</Str>
                <Str sr="arg1" ve="3">2</Str>
            </Action>
            <Action sr="act19" ve="7">
                <code>548</code>
                <Str sr="arg0" ve="3">AdBlocker Enabled</Str>
            </Action>
            <Action sr="act2" ve="7">
                <code>548</code>
                <Str sr="arg0" ve="3">Creating Directories</Str>
            </Action>
            <Action sr="act20" ve="7">
                <code>43</code>
                        <lhs>%status</lhs>
                        <op>2</op>
                        <rhs>2</rhs>
                    </Condition>
                </ConditionList>
            </Action>
            <Action sr="act21" ve="7">
                <code>548</code>
                <Str sr="arg0" ve="3">Disabling AdBlocker</Str>
            </Action>
            <Action sr="act22" ve="7">
                <code>162</code>
            </Action>
            <Action sr="act23" ve="7">
                <code>123</code>
                <Str sr="arg0" ve="3">truncate -s0 /etc/hosts</Str>
            </Action>
            <Action sr="act24" ve="7">
                <code>123</code>
                <Str sr="arg0" ve="3">echo "127.0.0.1 localhost
    ::1 localhost" &gt;&gt; /etc/hosts</Str>
            </Action>
            <Action sr="act25" ve="7">
                <code>410</code>
                <Str sr="arg1" ve="3">1</Str>
            </Action>
            <Action sr="act26" ve="7">
                <code>548</code>
                <Str sr="arg0" ve="3">AdBlocker Disabled</Str>
            </Action>
            <Action sr="act27" ve="7">
                <code>38</code>
            </Action>
            <Action sr="act3" ve="7">
                <code>409</code>
                <Str sr="arg0" ve="3">/sdcard/AdBlocker</Str>
            </Action>
            <Action sr="act4" ve="7">
                <code>409</code>
                <Str sr="arg0" ve="3">/sdcard/AdBlocker/status</Str>
            </Action>
            <Action sr="act5" ve="7">
                <code>410</code>
            </Action>
            <Action sr="act6" ve="7">
                <code>135</code>
                <Int sr="arg0" val="0"/>
                <Int sr="arg1" val="1"/>
            </Action>
            <Action sr="act7" ve="7">
                <code>43</code>
            </Action>
            <Action sr="act8" ve="7">
                <code>417</code>
                <Str sr="arg1" ve="3">%status</Str>
            </Action>
            <Action sr="act9" ve="7">
                <code>37</code>
                        <lhs>%status</lhs>
                        <op>2</op>
                        <rhs>1</rhs>
                    </Condition>
                </ConditionList>
            </Action>
            <Img sr="icn" ve="2">
                <cls>org.adaway.ui.BaseActivity</cls>
                <pkg>org.adaway</pkg>
            </Img>
        </Task>
    </TaskerData>
    Download xml file: https://www.dropbox.com/s/ajfekgpbkwm1h2f/AdBlocker.tsk.xml?dl=0
    Download APK file: https://www.dropbox.com/s/kbda8gkj9emlx9y/AdBlocker.apk?dl=0
  2. BeingIncog
    Nougat Feb 13, 2018
    BeingIncog , Feb 13, 2018 :
    Great Thread! :)
  3. idkwhoiam322
    Nougat Feb 13, 2018
  4. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Feb 13, 2018
    NeVeR_SeTTLe , Feb 13, 2018 :
    Thanks for this :) Will come handy ;)
  5. Dr. Indest
    GopalB., Punk_69, meatandy and 2 others like this.
  6. superplus
    Head Moderator Head Moderator Feb 13, 2018
    GopalB., 97pratyush, Punk_69 and 6 others like this.
  7. timebandit
    Oreo Feb 13, 2018
  8. Dr. Indest
  9. Rizla
    Jelly Bean Feb 13, 2018
    Rizla , Feb 13, 2018 :
    Dude, you're now my hero.
  10. meatandy
    Oreo Feb 13, 2018
    meatandy , Feb 13, 2018 :
    Thanks for the tip , Doc ! ;)
  11. Dr. Indest
    On that note, @David Y. mind changing my username to "Reboot101, MD"? My diploma should arrive in the mail within the next 2 weeks.
    idkwhoiam322, Punk_69 and meatandy like this.
  12. superplus
    superplus , Feb 13, 2018 :
    I'll pass on the request, in case the tag goes missing, like some of them seem to have been doing of late
  13. meatandy
    Oreo Feb 13, 2018
    You can now change your U-N yourself once from your profile. LOL
    idkwhoiam322 and Dr. Indest like this.
  14. superplus
    Head Moderator Head Moderator Feb 14, 2018
    superplus , Feb 14, 2018 :
    I was going to mention that :p but seems it might not work for users whose username has already been changed once upon a time, not sure though, so def worth a stab
    Dr. Indest, idkwhoiam322 and meatandy like this.
  15. Dr. Indest
    Lollipop Feb 14, 2018
    Dr. Indest , Feb 14, 2018 :
    Didn't know that, thanks.
    meatandy likes this.
  16. Dr. Indest
    I couldn't use a , so I changed it to this.
    Deleted
    Time to wait for it to be updated.
  17. BeingIncog
    Nougat Feb 14, 2018
  18. Rizla
    Jelly Bean Feb 14, 2018
    Rizla , Feb 14, 2018 :
    Yeah you need to log out and in again for it to update.
    meatandy and Dr. Indest like this.
  19. Dr. Indest
  20. BeingIncog
    Nougat Feb 14, 2018
    meatandy and Rizla like this.
