Add a "Daily Billing Cycle" of mobile data for Indian users
  1. Prateek96@Ind
    Eclair Aug 1, 2018
    Prateek96@Ind , Aug 1, 2018 :
    I use Dashboard widget and it only has the option to show used mobile data for a month and there is no option to change the number of days for the billing cycle.
    Since almost all the network providers in India now offer data on daily basis, I would request OP6 team to add a "Daily Billing" cycle option for mobile data.
    bhargav N Reddy likes this.
  2. camohan
    Marshmallow Moderator Aug 1, 2018
    camohan , Aug 1, 2018 :
    Doesn't the very same network provider which provides daily data quota provides the daily usage data too...??
  3. Prateek96@Ind
    Eclair Aug 1, 2018
    Not on dashboard :)
  4. camohan
    Well doesn't make sense to spend time and efforts just for displaying it on dashboard ;)
  5. Prateek96@Ind
    Eclair Aug 1, 2018
    To add an option for cycle of 1 day instead of 30, too much coding for you?
    irfanmoosani likes this.
  6. camohan
    That's my opinion not of the company. And I am not a coder but for sure I know it's much than just changing the number from 30 to 1.
  7. Prateek96@Ind
    Eclair Aug 1, 2018
    since there is no option to remove the data usage altogether from the dashboard, better add this option is what I suggested.
    And about the coding, not a very difficult task trust me.
    irfanmoosani and bhargav N Reddy like this.
