ads showing on homescreen
  1. PranavSavalkar
    Cupcake May 16, 2017
    PranavSavalkar , May 16, 2017 :
    why are the ads showing on home screen
    is it some kind of malware or something's is wrong with the system...
    help
  2. TheMystic
    Lollipop May 16, 2017
    TheMystic , May 16, 2017 :
    nothing wrong with your system. you have installed some app with many ads. identify and remove that app or use a adblocker like DNS66 from F-Droid.
  3. dj4800
    Ice Cream Sandwich May 16, 2017
    dj4800 , May 16, 2017 :
    remove the unwanted apps and scan with an AntiVirus once too.. also you may use adblocker
  4. G_Ng_KWAN_YEIN_WUZo
    Eclair May 16, 2017
  5. F_Valentin_Bacquet_FFVt
  6. G_sirusfaisal_qgKJ
    Eclair May 16, 2017
    G_sirusfaisal_qgKJ , May 16, 2017 :
    there is only one option for you bro... Reformat you phone start fresh. Even if you uninstall the app the ads virus may still be inside your phone system. Reset and don't back up.
    f00tbaLL and lostLambda like this.
  7. UKRYAN
    Jelly Bean May 16, 2017
    UKRYAN , May 16, 2017 :
    install malwarebytes from play store it will get rid of the rogue app doing this
  8. lostLambda
    lostLambda , May 16, 2017 :
    Dis ∆∆∆∆∆∆
  9. TheMystic
    there is no virus. he can install SD Maid. that will clean up all existing ad files and other unnecessary files. then use DNS66 from F-Droid. it is very effective and blocks over 80% of ads. may be more. also very light on battery too.
    G_sirusfaisal_qgKJ likes this.
