After Android 9 update, i am not getting ringtone volume on UI on clicking of volume button.
  1. jimmysonijs
    Cupcake Sep 27, 2018
    jimmysonijs , Sep 27, 2018 :
    Plz suggest.
  2. the_o2
    OnePlus 9 Series Expert Community Expert Sep 27, 2018
    the_o2 , Sep 27, 2018 :
    That's how Google change it, btw Press the volume key then you see the settings gear below the volume slider Tap on that and you should see the sliders for all the volumes. Change ringer volume from there.
    deangilvin likes this.
  3. jimmysonijs
    yes that i figured out. but it became two step process from earlier one step. OnePlus/Google should fix this.
  4. F1539798354195
    Cupcake Oct 17, 2018
  5. TheSnowfire
    Cupcake Dec 13, 2018
    TheSnowfire , Dec 13, 2018 :
    Look at the MIUI 10 by Xiaomi, they have a good answer to the problem...just a Button for more volume sliders, like the old Android versions. Why is there not such a feature in the new Android 9 Oxigen? On MIUI we see, it's possible
  6. ngydat
    Lollipop Dec 13, 2018
    ngydat , Dec 13, 2018 :
    Because MIUI 10 is based on Oreo, not Pie
    Artemus likes this.
  7. AshenPaladin
    Froyo Dec 13, 2018
    AshenPaladin , Dec 13, 2018 :
    Google is the one who implemented these changes in Android. You complaining in a OnePlus forum won't do anything.
  8. TheSnowfire
    I used a Phone with MIUI 10 before. it IS on Pie. And with the update to it, it changed the sliders to the side, media volume as main function of the Volume buttons. and they added a button like the old one to slide out the other sliders for ringtone and alarm
    you can look at the web, it's based on Android 9.
  9. ngydat
    My bad
  10. AshenPaladin
    Froyo Dec 13, 2018
    MIUI is a rather heavy skin. OnePlus's philosophy is to stay as close to stock as possible.
    Artemus likes this.
  11. TheSnowfire
    it will not make a big change to the design, but much more functionality.
  12. Romario Oliveira Pires
    Froyo Dec 13, 2018
    Romario Oliveira Pires , Dec 13, 2018 :
    It may be Google's implementation but OP can tweak it to their taste so saying that you shouldn't complain to OP regarding this is rather stupid
    Jan Kalwoda likes this.
