After applying temper glass finger print not working properly via OnePlus 8T
  1. sunilryali
    Cupcake Jan 16, 2021
  2. OALEXANDER
    Nougat Assistant Head Moderator Jan 16, 2021
    OALEXANDER , Jan 16, 2021 :
    Did you apply it on your own ? Or the store people did it for you.
    You can probably check with them if applicable for replacement subject to the tempered glass is defective .
  3. sunilryali
    sunilryali , via OnePlus 8T , Jan 16, 2021 :
    Own . Iam not able to fingers what should I do
  4. OALEXANDER
    I will recommend to show the device once to store.
    Coz I can't say if it's a TG issue or not.
  5. Safu_kp
    Eclair Jan 16, 2021
    Safu_kp , via OnePlus 8T , Jan 16, 2021 :
    Did you register the fingerprints again after you have applied the tempered glass protector?
    Had same issue. The fingerprint reading wasn't working properly. So removed the old fingerprint and re-entered new.
    So please try it. If it not working, then pls go to nearest OnePlus store.
