15
After updating slow charging via OnePlus Nord
  1. O1596792648952
    Eclair Mar 17, 2021
    O1596792648952 , via OnePlus Nord , Mar 17, 2021 :
    Moderator edit:
    Please read and use this thread for any discussion related to slow charging on the OnePlus Nord after the android 11 update.
    You can also use the feedback section on the community app to submit your issues directly to OnePlus
    Please don't create duplicate threads
    After the update of nord to os 11.1 the battery charging is too slow
    Before it took 51minutes to get full charged 100% in my nord using warp charger 30T .
    But after the update it almost taking 1hr 45min to get fully charged.
  2. O1603547776361
    Cupcake Mar 17, 2021
    O1603547776361 , via OnePlus Nord , Mar 17, 2021 :
    I am.also facing same issue and mobile is getting heated with normal use only.
    Frustrated to see this frkm Oneplus. Please fix this ASAP.
    60mins 42% charge- skmething is seriously wrong.
    srihari65, Azln999, arfatzain and 6 others like this.
  3. Nipu_1998
    The Lab Reviewer - OnePlus 9 Series Mar 18, 2021
    Nipu_1998 , Mar 18, 2021 :
    Please turn off the optimized charging feature of the device.
    It seems to be a bug with the optimized charging
    Axouuu83 and Rishindra Mani like this.
  4. Nipu_1998
    I would suggest to do a complete factory reset of the device.
    Please make sure to backup your data to some external storage before doing the reset.
    Axouuu83 likes this.
  5. O1596792648952
    Eclair Mar 18, 2021
    O1596792648952 , via OnePlus Nord , Mar 18, 2021 :
    Done already . Optimized chrgng option is off . But still the chrgng speed is like a normal charge
    Mangesh kalaskar likes this.
  6. O1596792648952
    Eclair Mar 18, 2021
    Factory reset also done after updating to 11 . Still problem persist
  7. I1601021310319
    Cupcake Mar 25, 2021
  8. Aaron2017
    KitKat Mar 25, 2021
    Aaron2017 , Mar 25, 2021 :
    Is optimised charging enabled? If so, your phone will charge at normal speed until it reaches 80% and starts charging slower for the remaining 20%
  9. dcschuitemaker
    Cupcake Mar 26, 2021
    dcschuitemaker , Mar 26, 2021 :
    I have the same issue here. Especially when using a 3rd party cable. The official charger with warp works fine. I use the latest 1.1.1.2 version.
  10. Shailender Sharma
    Marshmallow Mar 27, 2021
    Shailender Sharma , Mar 27, 2021 :
    Nope :)
    My device is charging as usual at Warp speed. I have the latest version of OxygenOS 11.1.1.2 update.
  11. B1608033491923 , via OnePlus Nord Gray Onyx , Mar 27, 2021 :
    Hi One Plus Nord users,
    This is to remind you of the slow charging issue which some of you have detected after the latest update of Oxygen OS 11.1.1.2 AC01DA
    If you are facing slow charging issue in one plus nord then try one of these of the following steps:
    1)Hold the Power Button Until Android Starts to Boot Up. As Soon as Android Starts Booting Up, Let Go of the Power Button. Then Immediately Start Holding Both the Volume Up and Volume Down Buttons. Continue Holding Both Volume Buttons Until Android is Fully Booted.
    This will ensure the removal of third party apps.
    Or you may try the second step:
    2)At first switch off the mobile by holding the Power button for a couple of seconds.
    In the second step push Volume Down + Power button until the OnePlus logo shows up.
    Draw the pattern or type in PIN.
    After that choose the language and select Wipe data and Cache option.
    I have tried the first one and charging issue is solved.
    I hope this will certainly work for the One plus nord users
    Thank you
    Ayush Singh.
  12. saibul
    Cupcake Apr 2, 2021
  13. Aaron2017
    KitKat Apr 2, 2021
    Aaron2017 , Apr 2, 2021 :
    Do you charge with optimised charging enabled? It charges the phone on normal speed until it reaches 80% and starts the slow down for how ever long after that depending on your charging pattern if it's enabled.
  14. B1604860054739
    Cupcake Apr 3, 2021
    Rishindra Mani likes this.
  15. #15
    X1610606977494 likes this.
  16. Aaron2017
    KitKat Apr 3, 2021
    Aaron2017 , Apr 3, 2021 :
    Do you charge with optimised charging enabled? This will slow down the normal speed after it reaches 80% thus it's taking longer to get it fully charged
  17. Arjun_Sna
    Cupcake Apr 3, 2021
    Arjun_Sna , via OnePlus Nord , Apr 3, 2021 :
    Greetings,
    Since the phone got upgraded to android 11. Charging speed has become very slow than normal wrap charging
    Taking nearly 2hrs for 0% to 100%
    Using orginal charger which came with box.
    Thanks
  18. @vkr8 , via OnePlus Nord Blue Marble , Apr 3, 2021 :
    No optimization is not enabled
  19. Buboleck
    Gingerbread Apr 3, 2021
  20. I1611643966288
    Cupcake Apr 4, 2021
    I1611643966288 , via OnePlus Nord , Apr 4, 2021 :
    I bought OnePlus Nord in the month of January 2021 and it took maximum 1 hour to get fully charged. Now it is taking near about 2 hour to get fully charged. Please help me what to do?
