22
After updating slow charging
  1. SumitB70
    Eclair Apr 19, 2021
    Bobbie63 likes this.
  2. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Apr 19, 2021
    mojoyoyo77 , Apr 19, 2021 :
    Moved thread to Oneplus Nord General Support
    Caoimhín likes this.
  3. pablofg1978
    Head Moderator Head Moderator Apr 20, 2021
    pablofg1978 , Apr 20, 2021 :
    Thread merged
  4. Y1618858501487
    Cupcake Apr 20, 2021
    Y1618858501487 , Apr 20, 2021 :
    Brand new phone with Oxygen OS 11.1.1.2 update takes more than 11h to get from 6% to 50% charged(not even full). This is outrages. I've tried with turned off phone, airplane mode, disabled the optimized charging, no wi-fi and everything and still the charging is REALLY slow.
  5. Ankith j jain
    Donut Apr 20, 2021
    Ankith j jain , via OnePlus Nord , Apr 20, 2021 :
    After updating to the latest version it takes almost 1.5 hrs to fully charge the mobile. Earlier it used to take max 45 mins to 1hr. Very disappointed on one plus team as this OS 11 update has shown more bugs than all other bugs on various OS.
    Mangesh kalaskar likes this.
  6. KluGe
    Lollipop Apr 20, 2021
    KluGe , Apr 20, 2021 :
    YEAH!
    Tell us something new!
    You did not read the reports here in this forum before you updatet your phone?
    Sorry, but then it is your own mistake.
    Before creating a new and redundant thead to a known issue and so only polluting our forum:
    Please use Search in the upper right corner!
  7. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Apr 20, 2021
    Liehjan , Apr 20, 2021 :
    You are not the only one... Read more about it in official update thread.
  8. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 20, 2021
    Caomhin , via OnePlus 6T , Apr 20, 2021 :
    Many factors can affect charging, even ambiant air temperatures above 20°c can slow down charging, as it gets hotter the phone cannot dissipate heat quick enough so will slow the charging down as a safety measure.
    But also try cleaning the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully.
    Check if this helps.
  9. abhirajsanap
  10. Bobbie63
    Marshmallow Apr 20, 2021
    Bobbie63 , Apr 20, 2021 :
    Turn off optimised charging.
    abhirajsanap likes this.
  11. pablofg1978
    Thread merged
  12. abhirajsanap
  13. Bobbie63
    And what is slow in minutes? Try if it changes when you restart your phone also try to carefully clean out the port with a toothpick or so, something non conductive.
    btw, which build are you on?
  14. Ankith j jain
    Donut Apr 20, 2021
    Own mistake?? Haha nice joke! It's OnePlus responsiblity to release a stable version rather than releasing an bugged version. Do you expect to go through each and every thread before updating into a new update? If yes, then great. I don't think anyone does it!!
  15. ashustan
    ashustan , via OnePlus Nord , Apr 20, 2021 :
    I am facing this issue of slow charging on my oneplus nord after the android 11 update the phone shows warp charging but charges slowly please help me fix this issue.😭😭
    santhosh_sankar likes this.
  16. Ankith j jain
    Donut Apr 20, 2021
  17. rohvar9
    Froyo Apr 20, 2021
  18. Tokolozi
    Most Original Avatar Apr 20, 2021
  19. Bibinpp
