After updating to 5.1.6 network signal strength became poor
  1. Dinesh Kumar Reddy B
    Donut Jun 10, 2018
    Dinesh Kumar Reddy B , Jun 10, 2018 :
    I have updated my oneplus to 5.1.6. After update my network signal strength became very poor. Previously its showing 3 points now it shows jus 1 or no signal. Kindly fix the network issue.
  2. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jun 10, 2018
    NeVeR_SeTTLe , Jun 10, 2018 :
    Some people are complaining that they have poor reception after the update.
    I would suggest you wipe your cache from Recovery. Then reset your network settings by going into --> Settings --> Backup & Reset --> Network Settings Reset and if these don't fix your reception problem, then submit a bug report here: https://forums.oneplus.net/feedback/
    the_o2 likes this.
  3. Dinesh Kumar Reddy B
    Donut Jun 10, 2018
    Tried this still same issue.. Guess I need to raise a bug..
    Thanks
    NeVeR_SeTTLe likes this.
  4. F_Martin_Jakobsen_eRgY
    Ice Cream Sandwich Jun 10, 2018
    F_Martin_Jakobsen_eRgY , Jun 10, 2018 :
    Here you go
