After upgrade to 11.0.8.14 i am having mic issue with cod mobile via OnePlus 8T Lunar Silver
  1. DoomBoyOG , via OnePlus 8T Lunar Silver , Jun 13, 2021 :
    After the patch update on 12 june 2021 i am having 2 issues.
    1. phone is heating a bit on the top side which i never faced before.
    2. while playing cod mobile game is taking mobile mic instead of earphone mic.
    I have tried restarting game and mobile but did not helped.
    i am playing cod mobile with same one plus wireless z earphones and also the game didn't updated yesterday.
    and everything was fine before yesterday's update.
    please fix this.
    Wick090 likes this.
  2. A.Saketh Gupta
    Ice Cream Sandwich Jun 13, 2021
    A.Saketh Gupta , via OnePlus 8T Aquamarine Green , Jun 13, 2021 :
    Once Go to app info , Check whether the Permissions are allowed or not & Once Force Stop the game and play again .. Now Check
    While charging your device please remove back cover , if the problem persists , Decrease Brightness
  3. SyamKG
    SyamKG , via OnePlus 8T , Jun 13, 2021 :
    Heating issue, especially top panel near earpiece is a pain for so long a time..yet there's no fixes.
  4. Wick090
    Froyo Jun 13, 2021
  5. Deva200
    Gingerbread Jun 13, 2021
    Deva200 , via OnePlus 8T , Jun 13, 2021 :
    I think u are facing battery drain issue...check for the apps that is running in background..go to battery settings , then special access and optimise individual apps that u don't use often...if you are not using google voice commands just disable google app..this will help you..if everything fails do a factory reset
  6. Wick090
    Froyo Jun 14, 2021
    Wick090 , via OnePlus 8T , Jun 14, 2021 :
    Already did that, still the above issues!!
  7. #7
  8. #8
