2
Airpod Pro + OP5T Terrible Call Quality
  1. BarneyHaywood
    Cupcake Feb 5, 2020
    BarneyHaywood , Feb 5, 2020 :
    Hi,
    Has anyone got any recommendations on using Airpod Pros with a OnrPlus 5T?
    Sound quality for music and calls is great, however, when making a call people on the other end say it sounds like I'm in a drain.
    I've tried resetting both devices, re-pairing the headphones and adjusting some Bluetooth settings but no luck. I tried the headphones on a different phone and the call quality is fine so the Airpods are ok.
    Any advice would be great!
    Thanks,
    Barn
    Omidfer2c and L1541082015614 like this.
  2. Waveform Modifier
    Marshmallow Feb 5, 2020
    Waveform Modifier , Feb 5, 2020 :
    Pretty sure Apple had done something where it wouldn't let you use everything on that earbud for good call quality. You better off use something that is not from Apple.
    CosmoKramer70 likes this.
  3. CosmoKramer70
    Jelly Bean Feb 5, 2020
    CosmoKramer70 , Feb 5, 2020 :
    Airpods are gonna be optimised for Apple products. You are better off using a more generic brand instead.
  4. L1541082015614
    Cupcake Feb 20, 2020
    L1541082015614 , Feb 20, 2020 :
    facing the same issue with my 6T. love the airpods for their small case, but have lots of connectivity issues and can't use them for calls at all. Everybody I talk to says they can't understand a word I'm saying. lmk if you find a solution
  5. Waveform Modifier
    Marshmallow Feb 20, 2020
    Waveform Modifier , Feb 20, 2020 :
    Use Apple product on Apple product than.
  6. Abhishek654
    Honeycomb Feb 20, 2020
    Abhishek654 , Feb 20, 2020 :
    because you're using two different environment devices Airpod pro has H1 chip and OP5T has qualcomm snapdragon which is way much diffrent from each other .
    always use qualcomm truly wireless
    my recommendation 1MORE triple driver earphone..
  7. L1541082015614
    Waveform Modifier
    Use Apple product on Apple product than.​
    Got them for the small case, because I carry them around all day in my Jean pockets. They work and sound great, except for the mic issues. Lmk if you've heard of a TWS IEM that sounds as good, has ANC and transparency modes, and has as small a case, I'm def open to recs
  8. Waveform Modifier
    Sennheiser Momentum TW (In my opinion, this sounds a lot better than Apple)
    Mobvoi TicPod 2
  9. L1541082015614
    No way, that case is huge! Pocket-ability is a big factor for me
  10. Waveform Modifier
    In my opinion, Apple sounds like crap
  11. L1541082015614
    I have better sounding wired IEMs, but the AirPod Pros are no slouch. Even Crinacle ranks them as a solid B. He only gave the Senn TW a C-
    乁( •_• )ㄏ
  12. Waveform Modifier
    I disagree with that review. He is entitled to his opinion.
  13. Omidfer2c
    Cupcake Mar 7, 2020
    Omidfer2c , via OnePlus 7T , Mar 7, 2020 :
    I have this problem too with airpod 2 and op 7t
    after I change my airpod 1
    when I listen to music every thing is ok but when make call on Street and noisy place call quality is terrible .
    please help me
  14. Waveform Modifier
    Marshmallow Mar 7, 2020
    Waveform Modifier , Mar 7, 2020 :
    Wrong forum
