2
Airpods problem
  1. VirgilOtto
    Froyo Sep 20, 2019
    VirgilOtto , Sep 20, 2019 :
    Hello. So I've recently switched from a oneplus 5 to a 7 pro and I have a problem with my airpods volume. Whenever I connect them to the phone, even if I put the volume at max, it still sound like half the volume from the oneplus 5. I've tried enabling and disabling absolute volume and I've tried reconnecting them and forgetting them but without no success. Anybody knows some solution?
  2. alanrushmore
    Gingerbread Sep 20, 2019
  3. youbi
    Portuguese POC Assistant Head Moderator Sep 20, 2019
    youbi , Sep 20, 2019 :
    That's strange. I've had it in the past in my old phone op6 or op5 (can't remember exactly), and by disabling the absolute volume it would be ok.
    But in the op7 Pro never had that issue. What version of the OS are you running now? I'm currently on android 10 beta already.
    Starcommander likes this.
  4. VirgilOtto
    Froyo Sep 21, 2019
    VirgilOtto , Sep 21, 2019 :
    and how can I do that?
  5. VirgilOtto
    Froyo Sep 21, 2019
    youbi
    But in the op7 Pro never had that issue. What version of the OS are you running now? I'm currently on android 10 beta already.​
    android 9, i don't have any intent to install beta right now. is it worth it?
  6. alanrushmore
    Gingerbread Sep 21, 2019
    alanrushmore , Sep 21, 2019 :
    Connect your airpod to iphone and wait for it to update. Before that take note of the current airpod version under setting,general, about. Scroll down look for Apple Airpod.
  7. VirgilOtto
    Froyo Sep 21, 2019
    okay, thank you, will try.
    L1568285156645 likes this.
  8. youbi
    Portuguese POC Assistant Head Moderator Sep 23, 2019
    youbi , Sep 23, 2019 :
    The stable update is out now. So maybe you can try it now. :)
    Maybe it could be this too, the truth is that I use the airpods also with my Mac pc, so maybe they got updated in the background and I didn't noticed it.
  9. VirgilOtto
    Froyo Sep 23, 2019
    VirgilOtto , Sep 23, 2019 :
    I also use Mac and it still didn't update. But you are right, I will wait for the stable and see what happens. Will keep you updated.
    youbi likes this.
  10. Starcommander
    KitKat Sep 23, 2019
    Starcommander , Sep 23, 2019 :
    I had this issue.
    Unpair the Airpods.
    Turn of absolute volume
    Reboot
    Turn on absolute volume.
    Repair the airpords.
    This solved for me
    youbi likes this.
  11. VirgilOtto
    Froyo Sep 23, 2019
    Not working for me :(
  12. VirgilOtto
    Froyo Sep 24, 2019
    VirgilOtto , Sep 24, 2019 :
    Nope..not even the update can solve it
  13. P1546059330838
    Cupcake Sep 25, 2019
    P1546059330838 , Sep 25, 2019 :
    still low volume i did everything if this issue continues then iam forced to switch to Iphone i dont want it[e]1f62d[/e]
  14. VirgilOtto
    Froyo Sep 25, 2019
    VirgilOtto , Sep 25, 2019 :
    I've talk to them in support. Lowkey they don't plan on really solving this issue unless there will be problems withwireless Bullets too...
  15. youbi
    Portuguese POC Assistant Head Moderator Sep 25, 2019
    youbi , Sep 25, 2019 :
    I find it very strange that you have it and for me its working fine. The truth is that for me it has been working great since long, only the early days I had some issues when I was still using the op6 or op5T (can't remember anymore).
    But not sure what other advice I can give you, it seems you tried most things already. Maybe doing a clean install and even use that clean install to update to android 10, and then try again to see if the issue is fixed.
  16. VirgilOtto
    Froyo Sep 25, 2019
    I sincerely don't know. But by the way, do you have the 1st or 2nd gen of airpods?
  17. youbi
    Portuguese POC Assistant Head Moderator Sep 26, 2019
    youbi , Sep 26, 2019 :
    Ohh, good question. I have the first version.
  18. gagan1215
    Cupcake Sep 26, 2019
    gagan1215 , Sep 26, 2019 :
    I am facing same issue...updated my airpods 2 today and since then volume is very low on my oneplus 7.
  19. VirgilOtto
    Froyo Sep 26, 2019
    VirgilOtto , Sep 26, 2019 :
    Oof...I have the 2nd gen...
  20. youbi
    Portuguese POC Assistant Head Moderator Sep 27, 2019
    youbi , Sep 27, 2019 :
    So it could be that indeed.
    Hi,
    Do you have version 1 or 2 of the airpods?
    Anyone else has the version v2 around here and got them to work fine?
    Because if its an issue just for version 2 I can try to pass that info to the dev team and hopefully there could be a way to fix it quickly.
