Airtel network issue
  1. W1512550578473
    Cupcake Feb 2, 2018
    W1512550578473 , Feb 2, 2018 :
    now I am using one plus 5 with oxygen os 5.0.1
    I am using Airtel Network in India when I am enable WiFi and Airtel internet after some time Airtel Network is gone and with out WiFi enable also Airtel Network is gone and when some one called me my phone didn't ring but those people got ring sound and some times not reachable this issue came after update my phone to oxygen os 5.0.1 please respond any solution to solve this problem
  2. Sharma996
    Gingerbread Feb 2, 2018
    Sharma996 , Feb 2, 2018 :
    it's happening while using first sim for internet and second sim for default calls.
    If using first sim for both internet & calls then no problem.
  3. Aashish.007
    Ice Cream Sandwich Feb 2, 2018
    Aashish.007 , Feb 2, 2018 :
    If it happens with Wi-Fi On and Wi-Fi off, why mention Wi-Fi in your post in the first place?
    Is is clearly independent of your Wi-Fi status.
  4. Ash645
    KitKat Feb 2, 2018
    Ash645 , Feb 2, 2018 :
    can you try this once? -
    -Turn phone off.
    -Then press power bottón and volume down
    -keep holding till it vibrates
    -Next choose English (or whatever language)
    -Then choose "wipe data and cache" option
    -Then make sure you chose "wipe cache" option
    -Reboot.
  5. Mishra1995
    Cupcake Feb 2, 2018
    Mishra1995 , Feb 2, 2018 :
    Faced same problem in 5.0.1 with jio as well as Airtel, nothing will help u as i already tried clear cache and formatting. After installing 5.0.2 not faced this problem till now.
  6. W1512550578473
    Cupcake Feb 2, 2018
  7. Mishra1995
    Cupcake Feb 2, 2018
  8. W1512550578473
    Cupcake Feb 2, 2018
  9. Mishra1995
    Cupcake Feb 2, 2018
    use vpn, connect to canada and check for updates, disconnect vpn and download the update (disconnect coz on vpn u will get slow speed)
  10. intrud3r
    Cupcake Feb 7, 2018
    intrud3r , Feb 7, 2018 :
    Did you find a solution? I'm experiencing same issues in 5.0.2 & Beta 5. Custom ROM's also had the same issue.
  11. Mishra1995
    Cupcake Feb 8, 2018
    Mishra1995 , Feb 8, 2018 :
    after installing 5.0.2 i wiped out cache and also done hard reset....after that it's working fine
