3
AIRTEL - VOLTE issue
  1. gowtham_selva
    Froyo Sep 9, 2019
    gowtham_selva , Sep 9, 2019 :
    hai friends.
    i am using Airtel sim(India).
    does anyone facing VOLTE issue.
    like VOLTE can't able to enable (or) VOLTE not working?
    especially in Airtel other network's like jio works fine with VOLTE.
  2. Y1528629554718
    Cupcake Sep 9, 2019
    Y1528629554718 , Sep 9, 2019 :
    i am also facing the same issue. i am not getting the option even to enable volte under settings menu. i am not facing this problem with other operators who has volte services like vodafone and jio.
  3. devangbucha
    Gingerbread Sep 9, 2019
  4. ssaikiran92
    Honeycomb Sep 9, 2019
    Z1564376699291 likes this.
  5. Y1528629554718
    Cupcake Sep 9, 2019
  6. gowtham_selva
    Froyo Sep 9, 2019
  7. Y1528629554718
    Cupcake Sep 9, 2019
  8. amlanbaidya
    Froyo Sep 9, 2019
  9. H1568048791403
    Cupcake Sep 9, 2019
    H1568048791403 , Sep 9, 2019 :
    where did you get OS version 9.5.13?
  10. H1568048791403
    Cupcake Sep 9, 2019
    same issue for me. reported to airtel many times but no use as of now.
  11. gowtham_selva
    Froyo Sep 9, 2019
  12. H1568048791403
    Cupcake Sep 11, 2019
  13. chandmansuri
    Cupcake Sep 12, 2019
  14. H1568048791403
    Cupcake Sep 14, 2019
    H1568048791403 , Sep 14, 2019 :
    after a long(nearly a month) fight with Airtel customer care and nodal officers, voLTE has come up. currently it's working in Hyderabad, hope it works in other cities as well.
  15. Harish KL
    Cupcake Sep 17, 2019
    Harish KL , Sep 17, 2019 :
    Solution which i did.
    I ported to airtel sim recently. The sim got activated but Volte is not enabled in my OP5. So check whether it is s/w issue of sim issue, I took my friends airtel sim and checked in my OP5. It displayed Volte icon in the status(Volte is enabled).
    I found out the sim is the actual problem. So i went to the airtel store and changed the sim again.
    They previously had provided me blank sim and ported to it. Now they gave me circle sim.
    Venkatesh_thota likes this.
  16. M0h1t Sharma
    Gingerbread Sep 18, 2019
    M0h1t Sharma , Sep 18, 2019 :
    he get it from oxygen os updater app, download it from play store and enjoy 9.5.13[e]263a[/e]️
  17. H1568048791403
    Cupcake Sep 18, 2019
    H1568048791403 , Sep 18, 2019 :
    okay.
  18. P1566999747620
  19. H1568048791403
    it's Airtel game.. actual they can configure any sim on any circle. I am able use voLTE in another circle after the issue got resolved with nodal officers.
  20. Naga_Sandeep_A
    Cupcake Oct 29, 2019
    Naga_Sandeep_A , Oct 29, 2019 :
    Sir r u postpaid or prepaid.When I was postpaid was getting volte when switched to prepaid I didn't get volte.Im currently staying in Hyderabad.Thank you
