Alaram issue in android 7
  1. O1574591726127
    Cupcake Dec 3, 2020
    O1574591726127 , Dec 3, 2020 :
    Hi,
    I am schedule two alaram one is 6.45 am and another one 10.30 am first one works poperly and second one only phone vibrate not ringning . Please fix this issue.
  2. camohan
    Nougat Moderator Dec 3, 2020
    camohan , Dec 3, 2020 :
    Hi there, there is a new update 10.3.7 https://forums.oneplus.com/threads/...-for-the-oneplus-7-pro-and-oneplus-7.1349407/
    You can probably check if the issue is resolved with this update, if not I would suggest you submit a bug report by going to Community app – tap the "+" sign – select "Feedback" – "Security" – "Fingerprint" and then fill out all the fields. By doing so, your bug report will be looked at by official Bug Hunters.
    Hope this helps.
    mojoyoyo_77 likes this.
  3. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Dec 3, 2020
  4. J4t1np4r3kh
    OnePlus Accessory Tester Dec 3, 2020
  5. O1574591726127
    Cupcake Dec 3, 2020
    jese pehle wali set kri thi wese hi
  6. J4t1np4r3kh
  7. O1574591726127
    Cupcake Dec 3, 2020
    nahi hui problem solve
  8. Oreo.
  9. J4t1np4r3kh
    J4t1np4r3kh , via OnePlus 7 Pro , Dec 3, 2020 :
    He claims to have set it in a similar manner to his other alarm, which seems to work fine
    Oreo. likes this.
  10. Oreo.
    Oreo. , via OnePlus 5 , Dec 3, 2020 :
    Yup but sometimes it is possible to miss some minor things
    J4t1np4r3kh likes this.
  11. O1574591726127
    Cupcake Dec 4, 2020
    O1574591726127 , Dec 4, 2020 :
    thanks it works
  12. Parth dhoni
    Gingerbread Dec 5, 2020
  13. Vishal ch
    Donut Dec 5, 2020
