3
Alarm icon keeps on showing in status bar
  1. Janidon2021
    Donut Jul 29, 2019
  2. 100[RP]_tk30
    Cupcake Sep 4, 2019
    100[RP]_tk30 , Sep 4, 2019 :
    It works!
    But what I did is to clear the cache and the data of the app (since I don't have anything to keep inside the app) instead of uninstall it, and the alarm is gone.
    For my case is Lunar Reminder App causing it,
    But I think it depends on the app installed/updated recently which has reminder feature
  3. Sachin A S
    Cupcake Oct 7, 2019
    Sachin A S , Oct 7, 2019 :
    Rather uninstalling the HealthifyMe, goto - settings - account - Troubleshoot - Reminder Not Working - Disable 'Use Alarm Clock'
    Which stops displaying the alarm icon all the time
  4. kishanbiswas143
    Cupcake Oct 17, 2019
  5. Abhilash 1291
    Cupcake Nov 6, 2019
  6. Waveform Modifier
    Marshmallow Nov 6, 2019
    Waveform Modifier , Nov 6, 2019 :
    Please read the thread before needlessly piling.
  7. hiteshthakker
    Cupcake Dec 10, 2019
    hiteshthakker , Dec 10, 2019 :
    Solution : Just turn off the trackmeal option in the Healthify Me and the clock sign will disappear..No need to delete the app
  8. G_SNEHIL_VASHISTHA_FQXE
    Cupcake Jan 7, 2020
    R1559145688480 likes this.
  9. Waveform Modifier
    Marshmallow Jan 7, 2020
    Waveform Modifier , Jan 7, 2020 :
    Please read before posting. Your "solution" had already been posted.
  10. H1605409752858
    Cupcake Nov 15, 2020
    H1605409752858 , Nov 15, 2020 :
    Hey I found that my other app was using my alarm clock and hence when I uninstalled that app, it disappeared. Later I installed it back and disabled alarms in that other app. It worked !
    App I was using was Healthily me, in which it was sending reminders to track meal so I disabled the same.
  11. Waveform Modifier
    Marshmallow Nov 15, 2020
    Waveform Modifier , Nov 15, 2020 :
    Please read the thread. Healthily had already been mentioned many times on this thread alone. Healthily is already a known app that is notoriously bad for that reason.
  12. sharaz.nabi
    Cupcake Dec 15, 2020
    sharaz.nabi , Dec 15, 2020 :
    HealthifyMe was creating the issue, that annoying unwanted alarm icon just vanished post uninstall of HealthifyMe.
  13. elogueil
    Froyo Jan 10, 2021
  14. elogueil
    Froyo Jan 10, 2021
  15. W1560943919078
    Cupcake Feb 4, 2021
    W1560943919078 , Feb 4, 2021 :
    Had the same thing and found another app causing it.
    I used an app called "Force Stop Apps" to close down all installed apps one by one until the alarm icon went away. Turned out to be an app called "Att Göra-Lista" by "Splend Apps". Basically an "To do list" app.
  16. Z1614865467557
    Cupcake Mar 4, 2021
    Z1614865467557 , Mar 4, 2021 :
    It just happened to me on a Nord and I have found a solution.
    This is definitely caused by third party app.
    The solution is: go to Setting > Apps & notifications > See all apps. Then click on the apps one by one and Force Stop. P.S. most common apps to do this (calendar, fitness apps, games)
  17. Mukund760
    Ice Cream Sandwich Mar 4, 2021
  18. gaurravv5
    Cupcake Apr 11, 2021
    #38
    sharaz.nabi likes this.
  19. #39
  20. giridhar_76
    Donut Jan 17, 2022
    giridhar_76 , Jan 17, 2022 :
    Just open healthifyme app and click Nutrition tab-> three dots option on top right-> Set Meal Reminder
    -> disable the tracking on the top right
    Solved
    #40
