13
Alarm not working
  1. Z1541938350202
    Cupcake Nov 18, 2019
    Z1541938350202 , Nov 18, 2019 :
    Same issue.. alarm doesn't ring.. it is happening since last three days. Looks like the app is being killed completely by RAM optimization. I used to love oxygen OS but looks like OnePlus is doing too much optimization and spoiling the beauty of it. My phone started hanging and doesn't respond until force restart.. happening every week. Not happy with 6T at all. I love my OnePlus 3 than OnePlus 6T.
    #41
  2. gentbajrami
    gentbajrami , Nov 18, 2019 :
    Same is happening here with Oneplus 7 Pro. Sometimes the alarm decides not to ring while no changes in settings from the day before when it rang. I have to restart the phone to fix it but this is not really a fix as it will repeat again randomly. This is a very serious issue and someone from OP should reply and acknowledge this. Functioning alarm is vital.
    #42
  3. V1559402471921
    Cupcake Nov 19, 2019
    V1559402471921 , Nov 19, 2019 :
    Unfortunately now, after updating to 10, I have the same problem. Clearing the app cache did not work, also there's no battery option available for this app.
    It's really boring...
    #43
  4. Brandon.Lau
    Cupcake Dec 14, 2019
    Brandon.Lau , Dec 14, 2019 :
    I had an alarm set for 22:30 last night. It ended up going off at 23:30. Anyone else have their alarm go off at a different time then what was set?
    #44
  5. BeNiess
    Eclair Dec 18, 2019
    BeNiess , Dec 18, 2019 :
    Why does this bug still exist in 2019?
    I have set about 4 alarms every morning to wake up but only 2 of them actually work..
    Annoying!
    #45
  6. V1559402471921
    Cupcake Dec 25, 2019
    V1559402471921 , Dec 25, 2019 :
    Just solved using Google clock app. Unbelievable that we have to use also a third-party app for allarm clock!!
    #46
  7. P1595588618768
    Cupcake Jul 24, 2020
    P1595588618768 , Jul 24, 2020 :
    i have got same issue on my OP5T.
    #47
  8. JulienIM
    Cupcake Sep 27, 2020
    JulienIM , Sep 27, 2020 :
    Thank you so much! My alarm wasn't making any noise for a whole week and I just went into the volume settings and saw that the alarm volume was set all the way to zero. I don't know how it got there, but I'll be sure to remember this fix. Thank you so much for sharing your advice!
    #48
  9. MaximChicu
    Gingerbread Feb 11, 2021
    MaximChicu , Feb 11, 2021 :
    Do you (or some of you) guys snooze your alarm by pressing volume buttons? Apparently (read the second part):
    "I initially had this problem and rebooted my phone, and that seemed to fix the issue. I also switched to using DnD schedules for when I'm sleeping instead of the alert slider. The combinatino of the two has fixed my problems with missed alarms.
    Also I noticed if you have your volume rockers set to snooze your alarms it will still modify the alarm volume. So if your alarms are at the lowest volume setting and then you hit volume down to snooze them, you basically mute your alarms."
    So it might be that that's HOW people are ending up with alarm volume at zero!
    By the way, this is a critical issue. OnePlus must solve it and/or make sure alarms work flawlessly (as supposed) in any other new models.
    Also: noticed that if notification sounds through earphones is turned on - the alarm will go off through the earphones, and not through the speaker (which is not very clever, especially as DEFAULT choice)
    #49
  10. N1615448835911
    Cupcake Mar 11, 2021
    N1615448835911 , Mar 11, 2021 :
    thank you for the best one. I admitted this one.
    #50
  11. YSRReddy
    Honeycomb Apr 13, 2021
    #52
  12. Onlymewithall
    Froyo Apr 14, 2021
    #53
  13. N1621177336567
    Cupcake May 16, 2021
    N1621177336567 , May 16, 2021 :
    I am also having an issue with the alarm on my Oneplus 8 VZW not making audio or vibrating when it is supposed to if at all...
    So far it had not presented issues but today it led me to be 20 minutes late to a production function where I was responsible for getting 90% of the equipment needing to be set-up to the venue.
    For a modern phone where alarm's are a core feature of a phone I find this to be fairly unacceptable compared to the likes of Samsung, iPhone, Motorola, ect.
    As we move out of a pandemic state I will also be traveling a lot a lot with nights spent in hotels and having an unreliable phone alarm is not something I can afford to have...
    Edit: I have traced this down and can confirm the issue is with the phone and not me sleeping through alarms - there have been days where I have been up and moving before the alarm but the alarm does not go off.
    #54
  14. B1556189628826
    Cupcake May 26, 2021
    B1556189628826 , May 26, 2021 :
    This is a one plus technique to slowly reduce the phones utility so we buy the next one. Really thought one plus was a good and classy company and above these cheap tactics. But incidents as such put an unremoveable stain on the brand which I will nor repurchase nor recommend to anyone. Infact I will ask my peers to stay away from.
    #55
  15. E1539898296613
    Cupcake Jul 16, 2021
    #56
  16. YSRReddy
    Honeycomb Jul 21, 2021
    #57
  17. X1631513998318
    Cupcake Sep 13, 2021
    X1631513998318 , Sep 13, 2021 :
    I just happened upon this thread after having an issue with the alarm myself. I haven't had any issue with the alarm being missed however I always wake up before the time it's set to go off. My problemi isI have the OP clock set to alarm even if the phone is off. The alarm will not sound random chat until the phone is turned back on. I attempted to capture a log to send to OnePlus via feedback tool however it cannot capture any logs when it's off and does not resume capturing when turned back on. Guess I'll go back to g clock.
    #58
