2
Alarm Problem - OP7
  1. eddyros
    Froyo Oct 3, 2020
    eddyros , Oct 3, 2020 :
    Hi everyone, two days ago I updated my phone to 10.3.5. Unfortunately, after that update, the alarm doesn't work...I set the hour, it switches to alarm mode display but it doesn't RING!! How can I fix it? Am I the only one with that problem?
    BekarisOrazbek and yashvidrohi like this.
  2. dikoscilator
    Gingerbread Oct 3, 2020
    mojoyoyo77 and eddyros like this.
  3. yashvidrohi
    Eclair Oct 4, 2020
  4. N1601772761599
    Cupcake Oct 4, 2020
    N1601772761599 , Oct 4, 2020 :
    I'm having the same issue, if anyone else knows what's going on because I never did any update
  5. L1579538980730
    Cupcake Oct 4, 2020
    L1579538980730 , Oct 4, 2020 :
    even my phone in 10.3.4 has the same issue. you will have to long wait til this issue would be fixed....
  6. eddyros
    Froyo Oct 5, 2020
    eddyros , Oct 5, 2020 :
    I solved the problem just deleting the data and cache of the Clock Application!
    TysonSW likes this.
  7. TysonSW
    Gingerbread Oct 5, 2020
    TysonSW , Oct 5, 2020 :
    This works!
    Thank you!
    eddyros likes this.
  8. NIKHIL048
    Cupcake Oct 5, 2020
  9. Bobbie63
    Marshmallow Oct 5, 2020
    Bobbie63 , Oct 5, 2020 :
    So did you read previous posts?
    KluGe, mojoyoyo77 and Artemus. like this.
  10. mojoyoyo_77
    Assistant Head Moderator Assistant Head Moderator Oct 6, 2020
    mojoyoyo_77 , Oct 6, 2020 :
    Thread moved to OnePlus 7 General Support
  11. mojoyoyo_77
    Even if you get a solution to the problem, do not forget to report the errors so that they can be studied. If it is solved by clearing the data from the Clock application, include this in the report as well.
    Please report bugs in Feedback or from the Community app / Profile tab / My comments / Button + / bug report
    eddyros likes this.
  12. TysonSW
    Gingerbread Oct 7, 2020
    TysonSW , Oct 7, 2020 :
    The problem came back again [e]1f614[/e]
    Did anyone create a bug?
  13. Chiragp830
    Cupcake Oct 22, 2020
  14. L1603423347902
    Cupcake Oct 23, 2020
  15. Basudev7
    Froyo Oct 23, 2020
  16. MalekAzim
