6
alarm ringtone problem in oneplus 2!!
  1. TheDiv23
    Gingerbread Dec 31, 2016
    TheDiv23 , Dec 31, 2016 :
    After the recent update of oxygen os 3.5.5, i am unable to change/set the ringtone. If i try to do the app crashes. Can anyone help?
  2. F_Nico_Rosero_ggxY
    Donut Dec 31, 2016
  3. aloksingh.07
    Eclair Dec 31, 2016
    aloksingh.07 , Dec 31, 2016 :
    Same problem for me to as reported earlier after OS update of 3.5.5 and still after updating with 3.5.6 still the alarm doesn't gets selected with any ringtone and only comes up with vibrate. When I select any ringtone or alarm tone, it goes back to default "unknown ringtone" and button shows at "none" it's problematic..
    Attached are screenshots.
    @ Mr. Tony - please note and address this issue in next FIX please.
    Thanks and wkr,
    Alok
    8556063664, Punnyabrata and TheDiv23 like this.
  4. Punnyabrata
    Donut Dec 31, 2016
    Punnyabrata , Dec 31, 2016 :
    I've started noticing this from the past couple of days. I suspect after the new update my phone's alarm works but there's no sound. It just keeps vibrating. When I try to select the ringtones for alarm clock the app closes. When I go back it says "unknown ringtone". I have deleted all alarms, deleted cache from clock app and just setup one new alarm. No go.
    Please help.
    G_Justin_Lee_tqkp likes this.
  5. Punnyabrata
    Donut Dec 31, 2016
    Please help.
  6. aloksingh.07
    Eclair Dec 31, 2016
    Same here. I have notified this complaint with all screen shots etc 3 times now in both 3.5.5 and 3.5.6 updates but NO acknowledgement yet from any OPT staff or alike...
  7. Siddhesh Vijay Kudtarkar
    Honeycomb Dec 31, 2016
  8. G_Anhat_Singh_AwXU
    Eclair Dec 31, 2016
  9. gamsurslick
    Honeycomb Jan 1, 2017
    gamsurslick , Jan 1, 2017 :
    That's exactly what's happening to me too. It was like this even before OOS 3.5.5/3.5.6 :/
    EzAs_OnePlus2 likes this.
  10. adeeb820
    Cupcake Jan 5, 2017
    adeeb820 , Jan 5, 2017 :
    Unable to select an alarm tone, address issue immediately, as my phone is my alarm. Thumbs down to one plus for great inconvenience, and otg never seem to function since day one.
    Mare1000 likes this.
  11. Mudit Bajaj
    Cupcake Jan 6, 2017
  12. dannyhwan
    Cupcake Jan 6, 2017
    dannyhwan , Jan 6, 2017 :
    same situation, this morning my phone was just vibrating but not ringing. You need to set again.
  13. itsbhanusharma
    Ice Cream Sandwich Jan 6, 2017
    itsbhanusharma , Jan 6, 2017 :
    Alarm tones can be set and are working Properly. Please check Your Slider settings if You maybe had disabled alarms over there. This may cause Device to vibrate and not ring.
    I had been able to change alarm ringtone in the clock app itself. Here is a screenshot of the same.
  14. markiyan619
    Cupcake Jan 6, 2017
  15. itsbhanusharma
    They are OP2 Owners not OP3/3T Owners. Please visit the correct forum
  16. OnePlus2_VKT
    Eclair Jan 6, 2017
  17. psychohits
    Cupcake Jan 6, 2017
  18. Asimisrar
    Donut Jan 6, 2017
    Asimisrar , Jan 6, 2017 :
    same problem here guys. i missed so many things due to this bug. they need to fix it right away.
  19. Asimisrar
    Donut Jan 6, 2017
    took me some time to realise that i was actually missing my alarms due to this bug. damn you one plus this is not good.
  20. Mare1000
    Cupcake Jan 6, 2017
    Mare1000 , Jan 6, 2017 :
    Same issue: can't change the alarm tone, which is stuck to a "nothing" tone, so it only vibrates.
    I can try changing it in the menu, but after I pick any tune, the only button I can press is back, and the alarm tone is back to "nothing"
