Udhaya_cpt , via OnePlus 8T , Jan 21, 2021 : I just upgraded from OnePlus 6T to OnePlus 8T , after the new update 11.0.6.8 I'm facing so much lag while toggling alert Slider from ring to vibrate , vibrate to ring takes 4-5sec to respond back And while typing keyboard is lagging a lot , anyone else facing the issue ? Can anyone tell me why this is happening ?
eastbay , via OnePlus 8T T-Mobile , Jan 21, 2021 : Try a reset, I wouldn't suggest a hard reset yet. If it continues. It brand new bring it back and swap out. Good luck also call one plus technical support
eastbay , via OnePlus 8T T-Mobile , Jan 21, 2021 : Thank you. Oneplus has been working on it. I don't know what they did but it's. Glad to be back!! ✌🏻👊🏻🙏🏻
tilak_gr.stark , Jan 21, 2021 : I tagged you in the wormhole. Check your notifications to head down there.
rodolfopoly , via OnePlus 7 Pro Nebula Blue , Jan 22, 2021 : How strange is that, try to do a hard reset
eastbay , via OnePlus 8T T-Mobile , Jan 22, 2021 : I'm doing fine thankyou. Happy to be back!! 👍🏻✌🏻 Great bunch of friends 👊🏻✌🏻👍🏻
eastbay , via OnePlus 8T T-Mobile , Jan 23, 2021 : Please listen to what I said. Try a reset, go into settings. Go down to system. Open reset. In the you see reset Wi-Fi and Blue tooth. Tap that. It resets the system. Try that first. If that doesn't work. Go to provider if this phone is new. Swap out. If they don't don't Help. call OnePlus toll free number. Talk to customize service. Tell them your issues. They should fix it or exchange it.
