10
Alert slider silent mode not working
  1. F_Martin_Hašpl_akWb
    Cupcake Jul 5, 2019
    F_Martin_Hašpl_akWb , Jul 5, 2019 :
    Wow. Thanks. That worked for me.
    It was poorly visible little dust, so I didn't notice before.
    Jeyr2012, shijomohandas and Nick 59 like this.
  2. G1552702106472
    Cupcake Jul 15, 2019
    G1552702106472 , Jul 15, 2019 :
    same issue is happening in my 6t.
    what is the solution?
    are the one plus support is fixing this problem?
    please guide.
  3. Waveform Modifier
    Marshmallow Jul 16, 2019
    Waveform Modifier , Jul 16, 2019 :
    Fix what? OnePlus can't fix user errors. Just like the user community can't fix stupid.
    Jeyr2012 and Kytharsis like this.
  4. shijomohandas
    Eclair Jul 20, 2019
    shijomohandas , Jul 20, 2019 :
    Cleaned and cleared some little dirt inside, but it doesn't helps.
    I am going to nearest service centre to get it fixed, will update the thread if it is solved.
  5. shijomohandas
    Eclair Jul 20, 2019
    Me too, Cleaned and cleared some little dirt inside, but it doesn't helps.
  6. shijomohandas
    Eclair Jul 20, 2019
    I Cleaned and cleared some little dirt inside, but it doesn't helps.
  7. Arjun Choudhry
    Honeycomb Jul 20, 2019
    Arjun Choudhry , Jul 20, 2019 :
    Giving the same reply thrice isn't going to make it start working again.
    G_Achuthan_J_mKZI and Nick 59 like this.
  8. I1548482938871
    Cupcake Jul 20, 2019
  9. Priyanshu Sharma
    Jelly Bean Jul 20, 2019
  10. Nick 59
    Marshmallow Jul 20, 2019
    Nick 59 , Jul 20, 2019 :
    Thread-jack much?
  11. Priyanshu Sharma
  12. rabinder.devnani
    Donut Jul 25, 2019
    rabinder.devnani , Jul 25, 2019 :
    I completely agree with Iordmada. I also cleaned the upper side of the slider and it works fine.
    lordmada likes this.
  13. lordmada
    Eclair Jul 25, 2019
    rabinder.devnani likes this.
  14. rabinder.devnani
    Donut Jul 25, 2019
    Clean the inside of alert slider using a very thin pin, should work. Worked for me.
    X1569940893233 likes this.
  15. mjdb71
    Gingerbread Jul 27, 2019
    mjdb71 , Jul 27, 2019 :
    And is the issue fixed? How? Repair?
  16. shijomohandas
    Eclair Jul 28, 2019
  17. muckid123
    Cupcake Aug 22, 2019
    muckid123 , Aug 22, 2019 :
    I had the same issue (cleaning didn't do the job), got the switch replaced 3 months ago and now the same issue again.
  18. Jaker21
    Cupcake Aug 23, 2019
    Jaker21 , Aug 23, 2019 :
    I've been having the same problem, just discovered how to make it work. If you press down on the slider as you slide it up, it will properly cycle through the sound/vibrate/silent modes. Hope this helps!
    #38
    winner_man likes this.
  19. mjdb71
    Gingerbread Aug 25, 2019
    mjdb71 , Aug 25, 2019 :
    I got a new OP7 Pro via Customer Service as it was a hardware issue
    #39
  20. Jose Lombardia
    Eclair Aug 26, 2019
    Jose Lombardia , Aug 26, 2019 :
    I have the same problem. I tried to clean it but doesn't solve the problem. Sometimes it works but if I repeat doesn't work until at least 20 times.
    My phone is in warranty, 2 years at EU, but OP can't solve my problem because I live in Canary Island, Spain, and OP doesn't send to the islands. And before somebody aks me, I bought it in OnePlus store at Amazon Spain. So he can sell me a 6T and send me it home, but doesn't repair it. Incredible!
    Now I'm trying to find a solution with Amazon but it seems stay some weeks without phone and spend some money to send it and to receive it again. Very poor service from OP
    #40
