10
Alert slider silent mode not working
  1. Vasilis_Giazitzis
    Cupcake Sep 11, 2019
    #41
  2. tsakalidis.p
    Cupcake Oct 6, 2019
    tsakalidis.p , Oct 6, 2019 :
    I am/was having this exact issue with OP7, and was just about to send it back for repair....until I removed the 3rd party case I had it in. And it now works like a charm - it also works with the case that it's shipped with, but not any other ones.
    I know what I wrote makes zero sense, but the slider now works - can anyone else test this to confirm that I'm not going mad please?
    #42
  3. Saurabhshipra02
    Cupcake Oct 9, 2019
    Saurabhshipra02 , via OnePlus 6 , Oct 9, 2019 :
    Wow, it worked I was facing same problem with my one plus 6 and now its working smoothly. Thank you so much. I would suggest this every one who so ever is facing this issue.
    #43
    Nick 59 likes this.
  4. Kytharsis
    Nougat Oct 9, 2019
    Kytharsis , Oct 9, 2019 :
    Funny thing: it's been suggested many many times yet people still ask.
    #44
    drl431 likes this.
  5. Saurabhshipra02
    Cupcake Oct 9, 2019
    Its because people only see your suggestions only when they face the problem. Its fact...
    #45
  6. Ranjit_Sasmal , via OnePlus 6T Mirror Black , Nov 6, 2019 :
    After reading the whole thread finally got the solution for Alert sliding for Silent option is
    1. Grab your Sim Card opening Pin
    2. Clean the Inner side of Slider on the right-hand Side.
    3. Try to push hard from Ring option to Silent option and do the Zig-Zag for 3 to 4 times.
    4. Restart your phone and It Should have been fixed.
    if still the problem continues Contact OnePlus Service Center for Hardware Change.
    #46
  7. rudidudi
    Cupcake Nov 13, 2019
    rudidudi , Nov 13, 2019 :
    I'm advised that the slider is not covered in the warranty but a paid repair
    Also, OnePlus is saying they don't have a complaints process.
    Im done with this crap, i was an advocate and now they just screwed us all over...
    #47
  8. wbshaw
    Cupcake Nov 23, 2019
    wbshaw , Nov 23, 2019 :
    Had the same issue, cleaning fixed. I used an air duster rather than trying to fiddle about with a pin. A good blast and it worked right away. Possibly dust caught under the slider which cleaning with a pin won't get.
    #48
  9. F1556921549834
    Cupcake Nov 28, 2019
    F1556921549834 , via OnePlus 6T , Nov 28, 2019 :
    I've recently been having exactly the same issue!
    A bunch of people have suggested cleaning out the slider but I'm not really sure how one is supposed to do that.... Advice anyone?
    #49
  10. drl431
    Marshmallow Nov 28, 2019
    drl431 , Nov 28, 2019 :
    You could try using a toothpick.
    #50
    Kytharsis likes this.
  11. Kytharsis
    Nougat Nov 28, 2019
    Kytharsis , Nov 28, 2019 :
    Toothpick or push pin if that's more convenient.
    #51
    drl431 likes this.
  12. F1556921549834
    #52
    Kytharsis and drl431 like this.
  13. drl431
    Great, thanks for the feedback!
    #53
  14. F1556921549834
    this is gonna sound really bad but I actually used the tip of a knife on this multi tool I have. but like, I reckon it's probably pretty dull by now considering I also use it sometimes to clean under my nails lmao
    #54
  15. Kytharsis
    Nougat Nov 28, 2019
    Honestly, anything that can fit between the grooves will work. All you're doing is clearing out debris or lint caught inside.
    #55
    drl431 likes this.
  16. Abdus samad khan
    Donut Nov 29, 2019
    #56
  17. Matodo
    Cupcake Dec 8, 2019
    Matodo , Dec 8, 2019 :
    Same issue here and I confirm that it works perfectly after cleaning the slider. I used a pin or needle for it.
    #57
  18. faztp12
    Cupcake Dec 18, 2019
    #58
  19. Kytharsis
    Nougat Dec 18, 2019
    Kytharsis , Dec 18, 2019 :
    Did you try the suggestions listed in this thread?
    #59
    drl431 likes this.
  20. Vinsmoke Syther
    Donut Dec 18, 2019
    Vinsmoke Syther , Dec 18, 2019 :
    The trick is simple.
    Use 'HAIR PINS' and dont apply pressure just sweep the dust off and also clean out the dust that is stuck on the slider itself (except the duct)
    #60
